My comfort zone infared heater is getting hot, i raise thermostat up to 86 and it,s not getting any hotter
Benimur
  • 6966 Answers
SOURCE: A thermostat versus an AC problem
"outside sensor error" is indicative of a Diagnostic error display, a feature where the device checks the functionality of each attached component. It would seem that your system has the optional "Outdoor Temperature Sensor" (probably P/N TSTATXXSEN01-B). The error then indicates that either that sensor is faulty or the hook up cable is unplug or defective. If you do not observed any critical changes in the comfort inside your home or the area that your system monitors/controls, then this only confirms that it is external and a sensor problem and does not affect the A/C and/or the variable speed furnace/comfort zone system. Normal faults could be the external sensor to cable connector/terminals being exposed to the elements and would require hard cleaning.
This sensor is not critical to the operation of the system and is optional.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
SOURCE: comfort zone 1500 infared heater
I have the exact same problem. How did you get it fixed ?
Posted on Oct 26, 2008
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Posted on Dec 06, 2008
  • 61 Answers
SOURCE: thermostat issue with comfort zone II.
Is this an electric or gass furnace - Eather of these can can have this problem its most recomendable that you call a seviceman .
in the case of electric furnace you may requier a new heat sequencer. And in the case of gass you may requier a new relay.
Posted on Feb 19, 2009
  • 17 Answers
SOURCE: I get the error code E2 It only shows 2 zones on my 4 zone syst
I reset the circuit breaker to the panel and everything is good now.
Posted on Jun 25, 2009
With Comfort Zone infared heater - how to change from C to F
Chances are this is not possible. Just figure out the temp you want in C and set it to that....
Jan 10, 2017 | Comfort Zone Heating & Cooling
I have a comfort zone infared heater the buttons will not work can power it on and off can control speed but nothing else
The thermostat may be fried inside. Try having it replaced at a Electronics store like Radio Shack or a YouTube tutorial video may provide you with the process of replacing the thermostat. The part should be fairly cheap.
Apr 27, 2016 | Comfort Zone Heating & Cooling
Infared heaters fan runs to long why
Defective temp sensor for the fans or the unit is just running to hot due to placement
Jan 16, 2012 | Comfort Zone Heating & Cooling
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
I turn the heater....it displays A04..and then it shuts off.
Comfort Zone heaters do not have a display board, they only had thermostat knobs.
Is it possible that you have a different model of heater?
Dec 23, 2010 | Comfort Zone Pool & Spa
I have a Weil-McLain hot water boiler for baseboard heat. The system has one circulator pump. The system has 5 zones - 3 work fine and two are not working. All the zone valves and thermostats are...
Hello.Prob#1 valve has a bad END SWITCH,change the power head,thad brings the circ on when open.Prob#2 try manual overide lever.iS IT TIGHT OR SMOOTH?DOES IT JUMP/SNAP?motor very hot? all bad signs.Change that power head too.The transformers are OK because 1 trans can only run 3 valves max.
Sep 20, 2010 | Honeywell (CT62B1015) Baseboard Heater
Comfort zone 1500 infared heater
Sep 18, 2008 | Heating & Cooling
Penguin a/c
the multiple zone thermostat should work fine but sounds like this one has an internal failure try replacing the thermostat
Jun 21, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
