Display is dark adjustment does not affect the darkness
    Top Expert:
  • Computers & ... Master
  • 8,213 Answers
Plug in an external monitor using a vga cable and if you can see your windows on the monitor then it could be what they call the inverter and that you will find behind the laptop screen it sits along the bottom this you will need to replace.
Posted on Dec 21, 2016
kman203
  • 99 Answers
SOURCE: Display is very dark
Dim screen is usually caused by a bad inverter board especially if you get video to external monitor. Usually cost $100-$200 depending on laptop.
Hope this helps!
Posted on Jun 11, 2008
Geekman
  • 32281 Answers
SOURCE: Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 07, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: dark display screen..how to adjust?
Hi, there is a key in your laptop which is called FN key. Press FN+ UP/Down Arrow for adjusting brightness.
Thanks & waiting for your feedback.
Posted on Feb 13, 2010
siawolf
  • 749 Answers
SOURCE: display to dark
in most cases there is a function key combination on your keyboard for adjusting the monitor brightness. look for the function key (f) and another key with a "*+-" and press them at the same time to increase or decrease the brightness.
also in your advanced display property settings in the control panel there is a driver level brightness and gamma adjustment that can be used.
Posted on Apr 01, 2010
SOURCE: hp laptop dark display
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Posted on May 06, 2012
I have a Garmin GPS on my boat I just bought But I can not see the screen it is very dark
there should be an adjustment for the display brightness. try looking in settings for this adjustment. Keep in mind the brighter the display the shorter the battery life.
Nov 22, 2014 | Garmin GPS
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
May 25, 2012 | Vizio VT Televison & Video
I have a dark shadow square 3"x3" in the upper left corner of my screen. Any thoughts on the cause of this?
Darkness in the display, specifically a localized discoloration is a fault in the display/monitor itself. If there was an issue with the motherboard or graphics processor, it would affect the entirety of the display.
The display is obviously still working aside from the dark spot, but this is often an indicator that entire display may soon fail.
Regards,
Dan
IT Professional
May 04, 2011 | Computers & Internet
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
My screen is very dark ...cannot adjust brightness...
Hi, if it is very dark to the point that it is almost black and has no light at all then there is a part in the display needs to be replaced, it is called fl tube. if the screen is dark but still there is somewhat some light then try going into the power setting, your pc might be set for low brightness to reserve power, see if you can adjust there, otherwise your display may just be going bad... Best of Luck
Jan 30, 2011 | HP OmniBook 6100 Notebook
Screen is dark
adjust it with, with the buttons, to increase the contrast,
either go to display settings in control panel,, and adjust your screen resolution and, brightneess
May 16, 2010 | Dell Latitude D600 Notebook
Gestetner DSm618d accidentally adjusted display too dark, now can't read it, so I can't control the machine, nor can I readjust ''contrast'' Vince
No matter how dark the contrast, if the room is dark you will be able to read it well enough to get to the settings -that is unless the display is burned out altogether
Oct 23, 2009 | Gestetner DSm618d Copier
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Nov 29, 2008 | JVC AV-27530 27" TV
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
