Error codeinstall black catridge
We changed catridge
I av hp officejet7310 wt an error msg- remove nd check right cartridge. Whch catridge is right? Is it d colour or d black?
The black cartridge.Try try another black cartridge, if this does not work you have to change thecarriage, if you can get it.
good luck
Apr 27, 2012 | HP Office Equipment & Supplies
My BJC-85 give an error message that need it to change the black cartidige and I did but keep the power and error light flashing
if the catridge has to click in make sure it`s in properly or take out the catridge and look for a mini green electronic chip if there is damage to that it might not recognize the catridge
May 16, 2010 | Canon BJC-85 InkJet Printer
On Initialization the following error appears 10.00.01 Supply Memory Error.
The printer cannot read the memory tag on the black toner catridge. Power the printer off, swop the black toner cartridge for another colour.ie put the cyan, magenta or the yellow in the place that the black should go and fit the black in to space left by the colour. Power the printer on and see if the error remains the same.If it's the same error then it could be the cartridge reader in the black position.If the error changes, then it's possibly down to the black cartridge.
Oct 14, 2009 | HP LaserJet 5550 Printer
Compatible cartridge for HP 1513 used in INDIA having 136 & 132
HP printers supplier, can arrange or supply in Hyderabad India,
the hp printer PSC-1513 catridge (color)136 and catridge 132(Black)
or advice us, where could we get said catridges. Thanks
Sep 03, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP D4160 printing only in b & w. Changed color cartridge. Have I messed up a setting somewhere?
yes you must have messed up the setting try change the cartridge i mean swap it, black for colour and colour for black, if it does not work, then make sure you bought the right one check the numbers of the one you changed, if its thesame, then return the catridge there must be a factory error or the catridge is a fake one. thanks
Jul 16, 2009 | HP Deskjet D4160 InkJet Photo Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
Error 1203 how do I fix it?
try this solution:
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
24 people viewed this question
k24674
jasbo
jasbo
