TDDGT 7 Day. Red light coming on and loud buzzing noise. Is this important??
  • 3 Answers
SOURCE: G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Posted on May 15, 2008
SOURCE: loud buzzing noise
RCA Scenium HD50LPW175 Lamp has been replaced. Very loud buzzing noise. sounds like the fan but maybe color wheel. Television is 2 yrs old. Not sure if it's worth fixing
Posted on Nov 30, 2008
  • 8546 Answers
SOURCE: Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Posted on Apr 10, 2009
  • 64 Answers
SOURCE: my freezer stopped freezing and is making a loud
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Posted on Jul 02, 2009
  • 117 Answers
SOURCE: loud buzzing noise with Whirpool microwave oven
The loud buzzing you hear is the sound of the magnatron tube.That is what emits the microwave radiation and buzzing should be normal. The mag tube may be nearing its end at witch time you will hear no buzzing and hence no heating of foods. Replacement can be costly depending on the model so most people just opt for a new one. Hope this helps
Posted on Jul 30, 2009
Our refrigerator does a very loud buzzing for 5 seconds 3 or 4 times a day what is the problem its only 3 months old and very annoying
Normally as loud buzzing from the fridge on that frequency it just the icemaker cycling, the water inlet solenoid valve often makes a buzzing noise depending upon water pressure. Other than the noise, there is nothing to worry about.
Sep 26, 2016 | Frigidaire Refrigerators
The e t c is buzzing what is causing this
ANSWERS: Oil Loss, Buzzing Noise, ETC. - Nissan Forum ' Nissan Forums
Mar 20, 2008 - 3) Yet another buzzing, rattling or whinning noise. If you own a Quest van, Maxima, Altima 3.5 and some Z/G/FX vehicles, and get a loud ... Mysterious no-spark situation with a buzzing transmission
Mar 31, 2013
ABS brake fault light on, buzzing sound
Feb 7, 2011
ECU making loud buzzing noise
Oct 6, 2009
Buzzing noise under the hood towards the back of the engine ...
May 8, 2008
More results from
Buzzing noise at 2000-3000 RPM - Nissan Forums : Nissan Forum
Oct 28, 2003 - 6 posts - ‎3 authors
The "buzzing noise"; I can tell that I am not alone in having this problem but has someone figured out ... I fit does, that eliminates the brake rotors, tires, wheelbearings, CV's etc. ... BUT with an Altima it is probable the pre-cats. Loud humming noise when driving
Aug 29, 2009
Noise when accelerating
Jul 21, 2009
engine noise/whine - 05 3.5SE
Nov 17, 2006
My altima has a humming noise under my hood
Jan 17, 2005
More results from
Jan 05, 2016 | 2000 Nissan Altima
I have a loud noise coming from dashboard when i turn the car on but heating/cooling system off
with high beams on without lights turned on the dash will buzz. turn off high beams during hte day to get rid of the buzz.
Oct 05, 2010 | 2004 Ford Explorer
Bugera 333xl every few seconds there is a loud buzzing. from
It looks as though you have ripple noise that amplifies into the output. First of all check if the mains voltage is going down to produce the low voltage hum. If not you will have to check the DC filter capacitors , couple in parallel to confirm the capacitor. IF the buzz is still coming through then you will have to isolate the preamp and wait it the fault is coming in. If not connect the preamp output to another amp to hear the same buzz to confirm the preamp to be faulty. If so you will have to trace by a voltage check when the buzz occurs to confirm if the preamp IC or the selector Ic is faulty. Some logic IC's can also produce this noise on static switching. If teh noise is appearing on both the channels, then I would still bet on the power section. So check once again on the rectifier/ regulators and capacitors. Hope this advice helps. Good day
May 16, 2010 | Audio Players & Recorders
I hav a loud buzzing noise thst shuts off the mic (X31)
Change the batteries. This is the symptom of batteries that are nearly dead.
Oct 06, 2009 | Voyetra Turtle Beach Ear Force X3 Wireless...
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Loud buzzing noise with Whirpool microwave oven when it comes on. All lights, heating and fan seems to work but not sure why loud buzzing. What is the problem?
Jul 30, 2009 | Microwave Ovens
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Buzzing Noise When trying to charge
it means your battery is too discharged to charge. when you plug the phone in, it doesn't use the AC power right away, it uses the battery to jump start it until the red lights come on the front, then it will switch to the AC power. try this. turn on the phone with out it plugged in and as soon as those front lights come on, plug the charger in. if the battery is not too discharged i.e. it didn't power down while you were talking to it, it should work. I went through three batteries until i figured it out
May 31, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Maytag gas dryer noise when burner comes on
The noise you are describing is coming from the gas valve solenoid coil assembly. This is usually indicative of weak coil.
If this is a warranty situation, request a factory authorized certified technician to replace the solenoid assy. at no charge.
If you want to fix it yourself, be sure and ask us for instructions on replacing the part safely.
Thank you for contacting us at
May 28, 2008 | Maytag HYG2460AWW Gas Dryer
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
