Dynaglo Torpedo heater blows major smoke and stops running. Can shut off and wait a while, turn back on and it will run fine fo a while, then does it again. What causes this, how do I repair
SOURCE: troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Posted on Jan 18, 2009
tinytrees
  • 92 Answers
SOURCE: pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Posted on Feb 05, 2009
steve_lima
  • 181 Answers
SOURCE: dyna glo torpedo heater has e 1 error code and shuts down
you either have too much air pressure or you don't have enough pressure.do you know what your pressure is set at.
Posted on Feb 17, 2009
heatman101
  • 43501 Answers
SOURCE: allpro torpedo heater runs for 5 secs then shuts
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
  • 69 Answers
SOURCE: i have a master 150000 btu kerosene direct fire
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Posted on Dec 10, 2010
Shuts down after about 30 seconds, blowing some smoke.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Nov 27, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
Heater runs for approx.2 minutes then starts to blow black smoke
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo orReddy heater...
heatman101
Oct 13, 2010 | Desa International Reddy Heater® RHER155B...
Heating & Cooling Logo
244 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
