Hot water cuts out when mixing with cold water
  • 143 Answers
SOURCE: problem with tefal quick cup,
Very strange problem for an air conditioner. I think you've posted this is the wrong category.
Posted on Jul 27, 2008
  • 101 Answers
SOURCE: No cold water from bathtub fixture/Shower won't engage
If you put on the cold and Nothing at all comes out, check the water supply valve to the tub. If it comes out alittle ...the washer probiblly came off and is stuck you will have to remove the valve ,but 1st check that the handle is not stripped ,and that is actually moving the valve to the open position Turn the handle and see if the handle backs out ,like its trying to open.
Please rember to leave me some positive feedback if Ive been Helpful! Thanks !
Posted on Dec 16, 2008
canbruce75
  • 1776 Answers
SOURCE: Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Posted on Jul 19, 2009
  • 129 Answers
SOURCE: Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Posted on Oct 10, 2009
Magaiver
  • 707 Answers
SOURCE: Valve will not mix enough hot water with
Their is a mixer valve if it is a one handle unit which is built in. It may be one half turn out of timing.
Posted on Aug 10, 2010
Hot water keeps running hot and old
Fastjet,
I can't understand what you are asking...
Please clarify via a comment.
perhaps a leak?
Jan 09, 2015 | Water Water Heaters
I have replaced moen 1225B cartridge and only get cold water no hot water
when installing a new cartridge you need to put stem grease on the o-rings or you are taking a great risk of cutting the o-rings upon installation. doing this will allow the cold water to mix with the hot causing this problem it is quite common for this to happen without the grease
Apr 16, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Water starts of hot but then starts to get cold.
You need to verify that you still have hot water. Sounds like you're running out.
Sep 28, 2010 | Home
Our tankless water heater is about 3 yrs old and when you take a shower the water is so hot it will burn you and when you try to cut more cold on it turns all the way cold we have it turned down as low as...
almost all tankless water heaters have this problem. I would install a small "buffer" tank. for example a small 5 or 10 gallon electric water heater will "mix" the water so that it doesn't come out of your shower cold, or scalding hot.
the instructions that came with your water heater should have a diagram of how to do this. if not let me know, I can send a copy.
the electric water heater acts as a mixing station.
the problem with most tankless heaters is that the water coming in is cold, average 60* and the water coming out is average 120*. sometimes the flame in the unit can't keep up when using large amounts of water, and you will get cold spots. when this happens, the heater will sense this, and then tells the flame it needs more BTU's, so then you will get extremely hot water.
the buffer tank will fix this by mixing the water before it gets to your shower and will give you an even water temperature.
let me know if this helps
Aug 22, 2010 | Bosch Water Heaters
Hello, Hot to very warm water comes out of the regular COLD water faucets throughout the house for about 45 seconds whenever the COLD water faucets are opened. I suspect that the thermostatic...
Yes the mixing valves do wear and give out........I had to put a micron filter in the input line to the hot water tank and solved the promlem for around 8 tears now. knock on wood....Hope this helps.
Aug 12, 2010 | Home
Possible Mixing valve Problem
I would pull the lines off the back and check the inlet filter on the hot and cold sides of the water inlet and clean the screen style filter. If you just use cold is the water cold if the cold water valve was bad then you would get no cold wate when set to cold.
Jan 20, 2010 | Maytag PAV2300 Top Load Washer
A/C blows hot air even though the lines are ice cold
When your A/C is on the supplie of hot water to your heater core is cut off.For some reason this is not happening.It could be your heater control switch(red/blue...hot/cold)is not working,or your mixing valve that adjusts the amount of hot water that is suppied to the heater core is stuck open.
Dec 31, 2009 | 2006 Suzuki Grand Vitara
Hot water pressure is fine, cold water is low.
You may have debris caught in the supply line or the mixing valve. You will need to take the unit apart after you have turned the water off and inspect those parts. Also, some of the new faucets have cut off valves already installed on the faucet, if you do make sure that they are fully open as well.
Mar 31, 2009 | Grohe Plumbing
Hot water first from faucet, two minutes later cold???
you could be having a problem elsewhere in house system! do you have a garden hose hooked up with a "Y" hose? or something in system were hot and cold connect...then a valve after? what happens is the hot water can back siphon through cold lines..its rare, but this happens, and is dangerous! water from hot water tank is full of bacteria, and if you drink it , well thats not good!
Mar 26, 2009 | Chicago Faucets CHICAGO FAUCET Mixing...
Cold water doesn't shut off
time to replace your water (mixing) valve. the diaphram tht regulates the water is wornand will no longer close causing the water to continually come in
Oct 11, 2007 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
