Question about Samsung Televison & Video
I have a Samsung Smart TV. Owned it for 3 years and everything has been great with it. Recently the picture went out, I have audio but no picture. I need help replacing what has gone bad? T-Con board?
MODEL# UN46D6900WFXZA I have watched the SHOPJIMMY videos on YouTube on diagnosis and repair, but still kinda unsure.
    Top Expert:
  • Samsung Master
  • 75,025 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 19, 2016
  • Jeff Brunk
    Jeff Brunk Dec 19, 2016
    Thank you, Don't think its the back light. I can see it through the back of the TV and the front glows, but no picture. There is a small white square on the bottom right on the screen though.
  • 132 Answers
SOURCE: I have a Samsung LCD TV Model LN-S4692D. I lost
You might want to try reseating all of the ribbon connectors that connect to the tcon first, but it sounds like you may have a bad panel(screen) which is probably what made the original tcon die. The only other possibilty would be the backlight inverter board(either the master or slave depending on which side the dark area is on).
Posted on Aug 29, 2010
  • 8909 Answers
SOURCE: bought a samsung 42' 4000
Why won't the Samsung Authorised Dealer repair the board? It's not that difficult!
There will be a power fault and the picture is not "building" properly. At worst it will be one of the memory chips.
With a reflo soldering machine, no problem.
Posted on Jan 22, 2011
Mas Baz
  • 177 Answers
SOURCE: i have the samsung fpt5084 plasma tv, and it has
I've watch your problem on youtube , that problem can be from main board. But to make sure main board problem, you should check without inputs first. Unplug all input (HDMI, Component, AV in, PC).
Than turn on your tv again. If that conditions still appear, i suggest you to call samsung technician to repair it.
Good luck.
Posted on Apr 07, 2011
SD Tech
  • 14553 Answers
SOURCE: Does Samsung tcon board fit Toshiba TV?
maybe we are smart enough to know better than to be inpolite.
Posted on Dec 06, 2012
  • 14 Answers
SOURCE: Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Posted on Jan 20, 2015
Testimonial: "Will do. Thank you, Jorge!"
I changed my mother board and power supply board on my Samsung smart 40" tv
Do this..on the remote push mute then 182 then push power, you will find the ability to flip the picture in there
Dec 15, 2017 | Samsung Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
My Vizio Smart TV has no sound
Sounds like you may need to replace the audio circuit board. If you are comfortable with taking apart your tv, you can find a dealer on this site who provides new and refurbished circuit boards for televisions. It is a shame that your tv is so new and causing you issues. Good luck and have a great day!
Aug 30, 2015 | Vizio M550SV 55 Inch Class Edge Lit Razor...
Samsung cs21m40mj no picture
I don't know if this helps, but I had the same problem in reverse. Great picture - no audio. I finally unplugged the TV and all devices connected to it (DVD player, cable box, etc.) waited 3 minutes and plug everything in. The audio was restored.
May 19, 2012 | Televison & Video
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
No picture anymore
I found one of these at the dump with the same issue. Bought a Z sustain board for $75 , replaced it and it works great. I plan on installing some PC style cooling fans in the cabinet as heat is what destroys these sets
Sep 08, 2009 | Akai PDP4273M Television
Televison & Video Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
