Can I hook up satellite to my digital labs dt191sa
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Digital labs 19 inch tv/dvd combo
Wish I knew the answer ... I have the same problem after switching to Dish Network (Satellite). It worked fine with Time Warner Cable. I'm suspecting the signal over Dish is analog (NTSC) which is not supported by this particular TV. I wish I still had the box and receipt!
Feb 01, 2010 | Televison & Video
Okay i have a digital labs 19" LCD HDTV/DVD and it works fine until you hook it up to an antenna cable, then it wont give channels when i auto scan. what should i do? buy a new cable or is it the tv
I have the same problem. Seemed to work fine with digital cable, but after switching to Dish Network, no luck. If I plug the AV cables (red/white/yellow) directly into the dish receiver, it works fine. The problem happens when I use it as a second TV connected via the RF cable wire. My only guess is that the dish receiver transmits the signal to the second TV via NTSC ... and the Digital Labs TV only supports ATSC and QAM. Hoping someone can confirm?
Jan 05, 2010 | eVision Televison & Video
Can this tv get satellite tv
Yes, provided that you have a satellite service provider. I hope this solution is helpful. Please take a moment to rate this solution.
Jan 23, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
My ge tv digital ready?
Your TV is NOT digital ready. IF you do not have cable or satellite, you will need a converter box. If you do have cable or satellite you have nothing to do or worry about as the cable or satellite box will automatically do the conversion for you. Hope this helps
Dec 20, 2008 | GE 25GT240 25" TV
Set up
The specs I am reading online are saying that it has digital coax connection. If your hooking up hd cable or hd satellite box some of those have a digital coax output on them. If your hd cable/satellite box only has optical out the system you have says it comes with a optical to coax converter which is pretty cool. So you should definately be able to hook up that sound system to your cable/sat box digitally for best sound. The only other way would be to run stereo red,white cables from your cable/sat box to your stereo as a last resort.
Nov 09, 2008 | Philips LX3950W System
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
27 people viewed this question
 Grubhead
Grubhead
