I upgrade the firmware and now device doesn't turn on. Any help?
  • kakima Dec 19, 2016
    Hi Kunchok c, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model device?
    Top Expert:
  • Audio Player... Master
  • 12,962 Answers
Something went wrong. Hopefully, you backed up original firmware and can go back. If not, you are screwed.
Posted on Dec 19, 2016
3 Suggested Answers
chansn
  • 18 Answers
SOURCE: Firmware upgrading - how long
please check the firmeware version and send me the screen shot of the software u r using for upgradition. pleasr rate this solution.
Posted on Sep 12, 2007
SOURCE: After Firmware Upgrade, my device does not power on. Help Please.
Someone let will place in the internet (rapshide..) and the thin line some of the new updating will pass
Posted on May 02, 2008
Have an iriver H10 - i turn it on and i get this message. " System files missing. To restore the system files, connect H10 to iriver plus" I did this and nothing worked? Can u help?
upgrade the firmware of your device follow this... How to upgrade firmware
1. Download the zipped file for your region.
2. Unzip the file and you will see *.exe file.
3. Connect your H10 to PC via provided USB cable and power on H10.
4. Once the device is ready, run the *.exe. It will automatically copy the firmware to your H10.
5. The progress bar copying firmware will be shown and your H10 device will give you 'Busy' message.
6. Once it's done, it will give you 'Upgrade Complete' message.
7. Please disconnect H10 with 'Safely Remove Hardware' option on your PC task bar.
8. Turn on the power of H10, go to 'Settings -> Extra ->Firmware Upgrade' and select 'Yes'.
9. Your H10 device will shut off automatically once the firmware upgrade is complete.
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate(EU)_v203.zip&filepath=/file/Down/
http://211.39.137.201//download.asp?filename=H10_5G6G_UMSUpdate_v203.zip&filepath=/file/Down/
Jun 06, 2010 | iRiver H10 MP3 Player
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
Tip
Motonav TN20 Firmware Fix
Motorola Motonav TN20 Firmware Fix
Does you Motorola Motonav TN20 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN20 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN20:
  1. Start by downloading the Motorola Motonav system software from Motorola from here.
  2. Extract the files onto an SD memory card.
  3. Make sure your Motorola Motonav is fully charged.
  4. Turn your Motorola Motonav off by holding the power button for at least 8 seconds, until the charging LED indicator blinks.
  5. Insert the SD memory card
  6. Turn your Motorola Motonav on. The software upgrade will begin automatically. Select “Yes to All” if prompted.
  7. The full upgrade process can take up to 15 minutes.
  8. When the software upgrade is complete, your Motorola Motonav will
  9. automatically load either the Map screen, Warning screen, or the Language Settings screen, depending on the state and configuration of your device.
  10. Remove the SD memory card from your Motorola Motonav navigation device.
The software upgrade procedure is now complete. Your Motorola Motonav is as good as new again.
I hope that helps.
_______________________________________________
Motorola Motonav TN20 Manual Download
Motonav TN20 Upgrade Manual
Motonav TN20 Firmware Download
on May 04, 2010 | GPS
Does not accept ( -)
the following characters are not permitted as part o fpassword for any devices. they have special meaning in DOS scripts.
` ~ ! @ # $ % ^ & * ( ) - _ = + \ | [ ] { } ;' " , . < > ?
so change your password.
Mar 31, 2009 | D-Link DVG-2001S (DVG2001S)
My creative zen 4gb player,when switched on the screen appears to be white
If you need to reset your device everytime you turn it on, it might be a firmware problem or device problem. You may want to try reloading or upgrading the firmware of your player. However, there are risk when you perform the upgrade. It might not work completely if it is not properly done.
For specific firmware upgrade instructions, please refer to the firmware released posted at http://creative.com/products/mp3 or follow the instructions on the screen.
Hope it helps!
Oct 21, 2008 | Creative Labs Zen V MP3 Player
Tip
Motonav TN30 Firmware Fix
Motorola Motonav TN30 Firmware Fix
Does you Motorola Motonav TN30 GPS lock up, freeze, or not load properly anymore? Replacing the system software / firmware of your Motorola Motonav TN30 GPS will fix these and other symptoms of corrupted firmware.
Follow these steps to fix the firmware / system software of your Motorola Motonav TN30:
I hope that helps.
Motorola Motonav TN30 Manual Download
Motonav TN30 Upgrade Manual
Motonav TN30 Firmware Download
Tip
I hope that helps.
on May 04, 2010 | Motorola Mobility MOTONAV TN20 GPS...
XA HD500 not recognized
visit at yourfreesoftwares.blogspot.com
Feb 11, 2008 | Computers & Internet
I just bought the Curtis MPS515
The Curtis site says that a Firmware update is required for this product. The firware update fixes a welcome screen as well as the computer not seeing the device issue - see download site in reply pasted below...
Q: When turned on, The WELCOME screen goes on but the unit shuts down after that even with new battery.
This may be caused due to damaged firmware but can be recovered by firmware upgrade. Click on the link given below to download the Firmware folder on your computer. When done, refer to file "procedure.doc", a Word file included in the Firmware folder, and follow the procedure to upgrade the Firmware of MP3 player. Download the Firmware folder at http://www.curtisint.com/html/custservice/manuals/CUR_MPS515_FW-UPGRADE.ZIP
Q: The computer does not recognize the MP3 player.
Upgrade the Firmware of the MP3 player, as procedure explained above.
Dec 25, 2007 | Curtis SMP228 MP3 Player
Tip
I hope that helps.
on May 04, 2010 | Motorola Mobility Motonav TN30 Car GPS...
 Grubhead
Grubhead
