Question about Winter Sports
My articat snowmobile
It smokes severly upon starts and i couldnt get it to go forward or back
2 Suggested Answers
SOURCE: wireing diagram for a 1994 articat 440z snowmobile
Probably a bad coil. Hopefully this helps.
Posted on Nov 26, 2012
How do i switch lights from bright to dim? I do not see a switch.
Push forward on brake handle to change from dim to bright.
Mar 30, 2014 | Arctic Cat 2004 F6 Firecat EFI
What would make the temp gauge on a 01 530i run all the way up to red and back to normal several times in a 10 minute trip?
Because its a BMW. The white smoke means your need a valve job on head. Probably losing some water thru head also.
Feb 17, 2014 | Computer, Chip, Cruise Control for BMW 5...
Have no lights and the gauges dont work
had that problem on motor cycle ,tore it a part and couldnt find anything then i started it an the starter button stuck halfway pulled out an everything worked
Feb 13, 2014 | Ski-Doo 2005 GTX Fan 550F
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Wireing diagram for a 1994 articat 440z snowmobile
Nov 26, 2012 | Cars & Trucks
I have a 2011 Subaru Outback, manual transmission with less than 600 miles on it. I noticed early on, when I first got the vehicle, that a cloud of smoke would exit the exhaust pipe when starting up the...
First of all, is it still under warranty? It sounds like water or oil in the exhaust. could be several issues, are you losing any oil or water. And yes this is a signal that there is a problem. Take it back to the dealer. You should have at least a five year 60k mile powertrain warranty.
Nov 22, 2010 | 2011 Subaru Outback
I leaned my lawnmower forward (on its front wheels) when I stored it. Now the lawmower is sputtering when I start it...There is smoke coming out the side of it. It only runs properly if I lean it on its...
most likely you have oil on top of the pistons and to much has gotten into the intake and exhaust valves. remove the spark plug, clean it or replace it, than pull the starter rope several times to exhaust some of the oil inside. install plug and start the mower. it might smoke some but should clear up.
Nov 20, 2010 | Mtd 22" Yard Machine Push Mower
Upon starting the 1995 Camry the engine dies. There is also grey smoke coming from the tail pipe. Checked the oil and there is no water in it.
Is it gray, bluish gray, or white? White smoke, during warm weather, indicates that you have a head gasket out and it's vaporizing water, it will look much like it does when you first start it on a cold day. Bluish gray indicates burning oil, which could be bad valve seating, severe engine wear on your piston rings and oil is blowing past them into the combustion chamber. Grey smoke is probably water as well, though it could be contaminated with oil, or the vehicle could be running too rich, getting too much gasoline. But typically this is more of a black smoke than gray.
Nov 10, 2009 | 1995 Toyota Camry
Big puff of white smoke at start up after sitting for several hours.
white smoke is water
blue smoke is oil.
nest time try and smell the white smoke see if it smells sweet?
if it does its antifreeze.
and also black smoke is fuel (like a leaky injector )
hope this helps
paul
Sep 19, 2008 | 2007 Nissan Altima 3.5 Sedan
Winter Sports Logo
103 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
