Question about Dryers
Dryer working fine won't start clean lint trap light blinking
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
  • 36 Answers
SOURCE: PF indication (Power Failure) and dryer digital light up but will not start
check your owners manual for clearing error codes in trouble shooting on theese electronic models lots of time you have to clear the codes to go back to normal ops by pushing certian buttons on kenmore i dont know which ones they are usaly its clear/cancel buttion some times you have to holld them so many seconds just unplugging it will make it think it has another power failure
Posted on Dec 29, 2007
  • 91 Answers
SOURCE: Lint fell off trap and down into dryer chute.
for the most if you want to clean it it will take you a while, depending on your model, disconect the unit from the power outlet first,from the back panel remove about 6- to 8 screws an then you will see the inside back panel expose to be vacumm, you'll see the back panel of the shoot that runs behind the dryer, take the i think 4-5 screws an vacumm it, i dont think is going to hurt your machine if a little fell in there, a quick way is try to remove the exhaust tube off the back an insert the vacumm cleaner, to clean the tube going out of the house you can use a strong shopvac, to **** it in or a leaf blower to push it out ...........good luck!
Posted on May 28, 2009
SOURCE: Keep getting error message AF druing drying cycle and I've cleaned the lint trap.
check for clog or kink in dryer vent
Posted on Jun 10, 2009
  • 13 Answers
SOURCE: Dryer stops drying and lint error message...
The symptoms sound quite similar to this problem. You could try out its solution?
Posted on Jul 20, 2009
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
My dryer won't work! The light works and the lint
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Aug 27, 2011 | Kenmore Dryers
My dryer has worked lights blinking check filter..I thoroughly cleaned the lint filter and cleaned behind and IN lint fliter trap and it still is blinking and WILL NOT let me dry anything....
No there is only 1 filter,typically once a error code is display unlit its clered it wont clear itself.refer to your owners manual to see how to clear the code
Aug 06, 2011 | Dryers
I have a Kenmore HE2 dryer that was working just fine. My husband stopped it in the middle of it's cycle to check on the clothes. He cleaned the lint trap and put back. When he closed the door and tried to...
you can unplug it for about 30 minutes, but I would venture to guess that the sensor which is located below the lint trap(if you look down the trap you will see to screws) is dirty and need to be cleaned, clean gently as not to break the sensor. Good Luck Tim
Feb 25, 2011 | Kenmore 85871 Electric Dryer
We just finished a load in the dryer and it worked fine. When we went to start another load it wouldn't start. The circuit works, it is plugged in, and the door is shut
Are your lint traps clean? Also, your vent hose going out the back of the dryer sometimes gets clogged up, and this will shut down your dryer until it is cleaned out. Try this, and if it still doesn't work - try shutting the dryer's circuit breaker off (or if its easier to unplug the dryer), and then back on again. This will reset the breaker, and then you can try running your dryer again. In fact, you can do the circuit breaker step first. If this doesn't work, then clean the lint trap, vent, etc. - and then return to the circuit breaker step. I hope this works for you. If not, let me know. I'll check back with you in a little bit. Good Luck!  Jim
Mar 29, 2010 | Maytag Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
