Question about Water Water Heaters
I have a John Wood powervented gas water heater, model 322152-001(13-05). The temp pressure relief valve is leaking. How do I operate/reset the valve manually?
Should the power/gas/water input and out put be OFF when manually opating the valve. Will a lot of water come out? I know it could be very hot, will a large bucket suffice? Thx. The handy housewife Nancy
  • Water Master
  • 3,315 Answers
There is a leaver YOU CAN PULL up but this may not stop the valve passing it may wash any dirt of the seating ,It may be best to change the valve .
Posted on Dec 29, 2016
50 gal. kenmore elite hot water heater model#153.332640 installed 05/01/2011 in February 0f 2017 it started blowing water out of relief valve. temp at faucet 145degrees . rplcd gas contr valve/therm
If the water coming out is really hot, you probably have a faulty thermostat, which allows water to overheat. If water is warm or cold, you probably have defective temp/pressure relief valve.
Jan 12, 2018 | Water Water Heaters
My pressure relief valve keeps blowing more so when it is hot any ideas please
Pressure relief valves open on high temperature as well as high pressure. They do go bad and are replaceable.
Consider calling the plumber. It is not very expensive part and the plumber can change it quickly.
If you just want to do it yourself:
  1. Write down the make and model of the water heater.
  2. Go to a real plumbing store and buy a new one.
  3. Turn off the heat source (the gas or electricity)
  4. Turn off the water inlet and open a hot water valve at any sink to take the pressure off the heater.
  5. Remove the old relief valve. It may take a long handled wrench.
  6. Install the new pressure relief.
  7. Close the sink valve.
  8. Turn on the water and check for leaks.
  9. Turn on the heat source.
Good luck.
Apr 11, 2015 | Water Heaters
I turned up the water temp on my gas water tank, and water leaked from the side pipe..do I need to repalce the pressure release valve or is this normal?
Any time your pressure release valve goes off you should replace it. the t&p valve responds to the temperature and pressure its possible that the setting you chose was to hot, or its possible that the relief valve was just worn out. I would replace that and keep your temp setting between B and C. another possibility is thermal expansion, check and make sure your expansion tank is good and if you don't have one I highly recommend it.
Jun 28, 2014 | Bradford White M45036fbn 50 Gallon Natural...
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 10, 2013 | Water Heaters
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Just purchaced a 99 jamboree with an atwood G6a-8e water heater. while on a trip I lit the water heater, and after 30 minutes someone told me water was leaking from the side. I noticed the pressure relief...
    It's gas operation only, but has electronic ignition for propane. ( just to confirm, if you look at back of water heater, it would have a metal or black plastic cover and hydro cable going in side or top of it.)
    There are usually 3 things that may cause pressure relief to leak. 1) Faulty,corroded pressure relief valve, which usually needs to be replaced if it goes faulty. 2) water temperature is getting too hot, which could indicate a faulty thermostat. 3) If your hooked up to city water, the pressure may be too high, causing excess pressure build up in hot water tank, thus pressure relief opens. If your running off your on board pump, this is probably not the cause, as they are usually set at 40 psi.
    Ist, - try pulling lever on relief valve slightly open ( careful it's hot !!) to clean out any calcium that may be logged on seal thus causing leak. If that doesn't do it, and the hot water isn't running out steady and appear to be under extreme pressure while leaking, then I'd change the pressure relief valve. Remember when you do, shut off water to system, and relieve pressure by opening a tap, and pressure relief as well after that. New one shouldn't be too expensive, just make sure you get same thread, 1/2"NPT or 3/4"NPT. Use a little teflon tape, or pipe dope whatever you prefer when re-installing as well as clean threads a little before.
    If it really starts gushing out pressure relief when heating or heated, and water seems hotter than normal, it's more than likely a faulty thermostat. I'll wait for your reply on what condition your experiencing before I go in to how to change the thermostat.
    Nov 17, 2010 | RTO Atwood Water Heater - 6 Gal LP
    Pop off valve on gas water heater making racket. Can just the pop off valve be replaced?
    Yes it can be replaced. This is a temperature/pressure relief valve and is the second most important safety device on your heater. They rarely make racket. Is it leaking? if so yes replace it. Water heaters should have a portion of water drained annually along with operating the relief valve. IF you raise the handle a few times, and it continues to leak, then it should be replaced. If you replace it be sure to replace it with EXACTLY the same temperature and pressure rating that is on it now. Allow the water heater to cool, and drain pressure before removing. If it is rumbling inside, you might have calcium deposits bouncing around in the bottom. Drain some water and see how it looks. (Often if you operate drain, and haven't in a long time it won't reseal)
    Aug 11, 2010 | American Standard 40 G Natural Gas Water...
    It quit working and I removed panel and reset it.now it seems to make the water hoter and it is making constant noise and leeking a little from the pressure relief valve
    The pressure relief valve is bad if it is leaking due to too hot of temp or it has gone bad. If it is hotter turn down the temp on thermostat and see if it quits dripping..
    If it's making a noise it may be heating the water the way above the limit for the relief valve.
    If it is the relief valve they have them at most hardware stores and can be replaced. When installing use teflon tape on threads if this is the problem.
    May 21, 2010 | Water Heaters
    Gas water heater is discharging out the pressure relief valve? what problems do i have?
    The water heater is over heating the water, possibly boiling it and causing steam pressure build up. The thermostat is not sensing the temp to shut off the flame. It would be wise to either have a repairman come out or replace the heater. If pressure builds too high and the relief valve cand keep up ,theer could be a rupure of a water lineSoooooooooooo, turn the gas off and git er done.
    Nov 09, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
    Burner lights but will not shut off. then pressure
    CHECK TO MAKE SURE THE WATER TEMP IS AT THE NORMAL OPERATING RANGE. USUALLY AROUND 120-130 DEGREES. IF IT IS, CHANGE OUT THE PRESSURE RELIEF VALVE. IF THE TEMP IS OUT OF SCALE, CHANGE OUT THE ECO AND TSTAT.
    Jun 28, 2009 | RTO Atwood Water Heater - 6 Gal LP
    Water Heaters Logo
    Top Water Heaters Experts
    vince
    80stech
    D. E. Hev
    Are you a Water Heater Expert? Answer questions, earn points and help others
