Question about Kodak EasyShare C315 Digital Camera
Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to: filesystem error e00100. what gives?
She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
Posted on Jul 29, 2009
Difficulty formatting new memory card for a Kodak Easy Share DX7440
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
Dec 01, 2011 | Kodak EasyShare DX7440 Digital Camera
Iam using KODAK EASY SHARE C43.When I inserted a 2GB micro SD memory card for the first time,it is saying 'Memory Card requires formatting' as usual.While clicking OK, It shows 'formatting.....' and then...
The best thing would be to borrow a laptop or PC with a card slot, and format it there.
If it continues to show error when formatting, the card is defective and should be replaced. (Returned?)
Out of 5 memory devices I have bought in last 3 years, 2 came with a free virus. This from reputable stores. Be sure PC has antivirus installed.
It is not at all unusual these days to find NEW memory devices that don't work. Production methods are cheap as they can be. Just return it for refund or exchange.
Feb 15, 2011 | Kodak EasyShare One Digital Camera
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
Kodak Easy Share z740 won't format Kodak Memory
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button.
  5. Follow the prompts to format the memory card.
Retrieved from www.kodak.com.
Mar 29, 2010 | Cameras
Cant get my camera to format a memory card
agreeing with fixer1950. This model is in fact just designed for up to 2GB SD or MMC card.
When Easyshare one was released, 4gb SDHC was not yet created. You will always get the "memory card requires formatting" (looping until you get a file sys error msg) if you will keep on trying to use the 4gb.
Aug 12, 2009 | Kodak EasyShare One Digital Camera
I have a kodak easy share c734 and i bought a 16 gig memory card and all i get is format card message.i have formated the card several times with the camera and with my computer and i still get the same...
Most Kodak cameras only allow you to use up to 2gig memory cards. When I was on holiday I bought a 4gig for myself and I was told after that it would not work on it. I tried formating it everything but nothing works.
Jun 28, 2009 | Kodak EasyShare V530 Digital Camera
Kodac easy share c330 says memory card full, but it is a new card
Which size has the memory card? More than 1GB?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
May 03, 2009 | Kodak EasyShare C330 Digital Camera
New memory card will not format
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
Mar 23, 2009 | Kodak EasyShare V550 Digital Camera
Kodak memory card error
Hey hardygurl198,
What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 08, 2008 | Kodak EasyShare C310 Digital Camera
Kodak EasyShare C315 Digital Camera Logo
729 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
