Question about Avital Vehicle Parts & Accessories
Avital Remote starter LED light wont come back on. Help please.
I installed an Avital 4103 L remote starter. I had one fob paired, then accidentally zapped the starter with the bitwriter. The remote start box is no longer responding for me to pair the remote again. Please help.
  • 34 Answers
SOURCE: im about to install a
the one you need to use is the wire that shows a 12volt power in cranking posision
Posted on Jan 09, 2009
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
logosc75
  • 625 Answers
SOURCE: i have a problem with
If this is the factory alarm going off when you remote start the vehicle, the factory disarm wire is not connected. If you would list the year/make/model of the vehicle, I could direct you to the wire.
Posted on Feb 25, 2011
  • 1833 Answers
SOURCE: replacement remote for avital 477L. how do i pair
Here I am described four ways to pair the alarm with the remote.
1st way:
Put the key in your vehicle's ignition and make sure all the doors and the trunk are closed.
Turn the key two clicks to the right, one click short of the "Start" position before you do anything with your replacement remote.
Press and release the "Override" button on your remote car alarm remote five times in less than eight seconds.
Press the "Lock" button on your car alarm remote.
2nd way
Purchase a new remote from the dealership or automotive store where your alarm system was installed. Make sure the remote is the same brand as the system that you have installed.
Sit in your car with your remote and ignition key. Insert the key into the ignition, turn it to the "ACC," or Accessories, position and leave the driver's door open.
Wait for the chimes to stop and press the "Valet" button on your remote.
Wait for the alarm to chirp once, press and hold the "Valet" button again and press the button you would like to program; do this while holding the "Valet" button.
Wait for the horn to chirp again and release the button that you are programming. Release the "Valet" button and remove your key from the ignition to end the programming of the new remote.
3rd way
if it has the button in the antenna. Turn the ignition on then off within 7 seconds hit the button(antenna button) 5 times it will chirp (telling you it's in program mode) if you have viper two button hit both buttons at the same time do both remotes one after the other (led will flash to confirm programming is done) this should fix your problem.
4th way
Click on the following link and go to the page no 3 and 4???
http://www.directeddealers.com/manuals/og/avital/G834002_07-04.pdf
LCD 2-way configuration, Standard 4-button configuration.
It will solve your problem. Best of luck.
Posted on Sep 14, 2011
  • 52091 Answers
SOURCE: I have a 2004 ford mustang. I bought the car about 6 months ago and it had an avital 4103 remote starter installed. The remote start stopped working. Says neutral safety shutdown. How do I fix this?
Many of the remote starters installed had to have a coded key installed in them . possibly you r coded key fell out or lost it's code .
Posted on Jan 29, 2016
I need to know the steps ( opening driver door, turnig the key on n' off etc,etc. ) to activated the alarm 4103
The 4103 is not an alarm! It's a keyless entry and remote starter. So...what are you trying to do.
Feb 13, 2013 | 4103LX Remote Start System with Two...
I lost my remotes for my remote start 4103. I have an unused keyless entry model 2101. Does anyone know if the remotes are interchangeable so that I can have the new ones programmed to operate my remote...
It is not likely that they could be used interchangably. The reason is the narrow radio spectrum that is used and the desire for such companies to produce proprietary pieces.
It is is possible if you were to get a Fob for a 4103 off Ebay for example, they could be resynched. But the remote start is going to have a different signal than the remote door lock. just so they can be operated independent of each other. So it is not likely the 2101 would do more than sync to the door locks.
Feb 18, 2012 | Remote Start with Two 4Button Remotes ...
I have a problem with my avital 4103 remote starter everytime i try to start try to start my car my car alarm goes off
Feb 24, 2011 | 831002/4100 4100 REMOTE START SYSTEM WITH...
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Hello. I have an Avital 4103 system and the key light on the dash does not go out after starting the car, inserting the ignition key and turning. I can drive the car, but the key light keeps flashing and...
I have a Dodge Caravan 2001 SE. Had the Avital 4103 installed. My question is, before installation i had a Chrysler car alarm in the van. When the remote start was installed they removed the alarm.
The shut down toggle switch was not installed, also the push button valet switch was not installed also. Is this a correct installation, I was told that I did not need the last two items to be installed.
Oct 27, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Vehicle Parts & Accessories Logo
70 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
baire
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
