Need to change my clock from 24 hour to 12 hour time it's model sharp SPC570
    Top Expert:
  • Audio Player... Master
  • 51,348 Answers
Press the mode button to get 24 or 12--- set on 12
Posted on Dec 19, 2016
How do I convert clock from 24 hr display to 12 hr display on my GE profile gas oven with digital display?
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out
Your control is set to use a 12-hour clock.
If you would prefer to have a 24-hour
military time clock or black out the clock
display, follow the steps below.
Press the BAKE and BROIL HI/LO
pads (on models, use
the upper oven controls) at the same
time for 3 seconds, until the display
shows SF.
Press the CLOCK pad once. The
display will show 12 hr. If this is
the choice you want, press the
START pad.
Press the CLOCK pad again to
change to the 24-hour military time
clock. The display will show 24 hr.
If this is the choice you want, press
the START pad.
Press the CLOCK pad again to black
out the clock display. The display
will show OFF. If this is the choice
you want, press the START pad.
NOTE: If the clock is in the black-out mode, you
will not be able to use the Delay Start function.
Oct 04, 2017 | GE Kitchen Ranges
Setting the Sharp atomic clock SPC315
Sharp SPC315 Clock Setup Instructions
Set Time Hours and Minutes:
Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Adjust/Channel button to change the hour.
Press the Time/12/24 to go to minute
Press the Adjust/Channel button to change the minute.
Press the Time/12/24 to set.
Set Alarm1 and Alarm2:
Press the Alarm1/Alarm2 button to toggle either Alarm1 or Alarm2 to set.
Pres the Alarm1/Alarm2 and Alarm2/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press the Alarm1/Alarm2 to go to minute
Press the Alarm1/Alarm2 to set.
Set Calendar Year:
Press Calendar/C/F and Max/Min buttons at the same time for two seconds and it will start to blink the calendar year.
Press the Adjust/Channel button to change the year.
Press the Calendar/C/F to go to Month.
Press the Adjust/Channel button to change the Month.
Press the Calendar/C/F to go to Day.
Press the Adjust/Channel button to change the Day.
Mar 01, 2015 | Sharp Atomic Weather Station Alarm Clock...
How to change from 24 hour time to 12 hour time
The change from 24 hour to 12 hour display is semi hidden. I found the instructions and followed the set up, this change follows the settings for minutes in the sequence, so right after you set minutes on the clock push up or down and that will change the 24 hour clock.
Mar 07, 2014 | dr. Tech WF-1070T Home Wireless Weather...
Sharp spc570 -cant change from 24hr military time to 12hr time
All you have to do is press and hold the - (minus) button on the front of the alarm clock to toggle it between 24h and the 12h format. But only when in normal operation mode. If you are in any of the setting modes it will obviously change whatever setting your in in a downward direction.
Aug 24, 2013 | Audio Players & Recorders
My Koss KS7322-2 is stuck in 24 hour format, how do i set it back to the 12 hour clock?
Press and hold the "clock" button. You need to hold it for what seems like a long time - 10 seconds.
May 07, 2012 | Audio Players & Recorders
Timex 1440 sport indiglo 50m convert from 24 hour clock to 12 hour clock.
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
Dec 06, 2010 | Watches
How do we set the clock on Sharp logicook R-7N76?
Press stop/clear pad to remove 88:88 from the display.
Press auto start once for 12 hour clock and twice for 24 hour clock.
Enter hours first using 10 minute and 1 minute pad (i.e. for 12:00 - press 10 min button once and 1 minute button twice)
Press auto start.
Enter minutes as before using 10 min pad and 1 minute pad (i.e. for 35 mins press 10 min button 3 times and 1 min button 5 times)
Press auto start.
Jan 22, 2010 | Sharp Office Equipment & Supplies
How to set clock on sharp microwave
normally you look for the clock ot watch icon. Pressing it once will give you the option for 24 hours setting. Press it twice and it will give you the opportunity to set to 12 hours setting. Using the no. keypad, punch in the time and then repress the clock icon again.
Sep 21, 2009 | Sharp R-1480 Microwave Oven
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
 Grubhead
Grubhead
