Question about Lomo Photography
Film not releasing on lomo instant. Any ideas on how to troubleshoot? this happened out of the box.
  • Lomo Master
  • 5,412 Answers
When you say not releasing, do you mean you are unable to rewind the film ? Have you pressed the rewind button ?
Posted on Dec 19, 2016
I don't know how to roll up the film after it's done. I ruined the last one. How do I roll up the film?
There is a crank located on the top of the camera. Some Lomo's Ive seen have it located on the left, but it will always be on the side of the camera where you placed the film. Many cameras will also have arrows indicating what direction to turn it in order to wind the film back in. If there are no arrows, place your ruined roll of film (or a new roll of film) into the camera, and try winding it with the back open (if you're using a new roll of film, don't roll it all the way in, or you'll waste another roll).
If there is no crank, or it is broken, you can always unload your camera in perfect darkness (no red lights), and wind it back into the canister by hand.
Mar 10, 2011 | Lomo Fisheye 35mm Film Camera
How do I get my lomography fisheye to advance?
Turn the thumb wheel located behind the shutter release button until it stops at the next frame.
Note that on your model the MX button (Multiple eXposure) to the left of the thumb wheel often gets stuck and prevents the film from advancing. The button should be firmly to the right when not in use. If the MX system is broken there's nothing you can do as the parts cannot be repaired or replaced. All LOMO and Holga models are extremely cheaply made plastic "toy"cameras and are not designed to last. Most have a maximum design lifespan of ten to twelve rolls of film, the FishEye model is designed to last just half that. It's only in Western countries that these models sell for ridiculously high prices, as an example my Lomo FishEye cost me 48 Hong Kong Dollars (that's just under GBP£4 or just over US$6). Back home in the UK they sell for ten times more.
The above explanation is not meant to be disparaging about your camera, but is just to illustrate that these cameras are really built from the start as disposable cameras which have the added bonus of being reusable a few times so cannot usually be repaired when broken.
Oct 09, 2010 | Lomo Fisheye 35mm Film Camera
I put the film in my camera backwards(with the tail of the film facing to the left) and i cant get it back out. when i tried pulling up on the rewinder thing part of it snapped off
If it was just the folding lever part of the rewinder which has broken off then you'll need to use a flat bladed screwdriver or the tip of a knife to lever up the rewind knob sufficiently to pull it up and open the camera.
If you've broken any more than that, then your camera is unrepairable. Spare parts are not available for your camera as it's only designed to last for six rolls of film. Even regular Lomo and Holga models are only intended to last for a maximum of twelve films.
Oct 02, 2010 | Lomo BRAND Fisheye 2 Camera UK seller...
I have just developed out my film and realise it has a constant blue streak/line across the top of every photo. it is slightly obvious in some of the photos. may i know what might possibly cause that?
What you describe is typical of a film which is getting scratched as it is used in the camera, either due to dirt or debris in the camera, a rough finish to a camera part in the film path, or even just a faulty film cassette which had a bit of grit in the light seal when the film was rewound. It's very common in cheaply made plastic toy cameras like Lomos and Holgas.
If it happens all the time, it's a camera fault. If it's intermittent it's either a camera fault or a processing lab fault, but most labs run regular test rolls through to ensure these faults do not occur. If it's a one-off, then it was probably a bit of debris in the film cassette light seal.
If the fault is in the camera, lay the negative across the back of the camera and then look and feel anywhere in the film path that the line appears along to find the problem. Rectification usually means a bit of cleaning, or smoothing down with a sharp knife or fine abrasive and be very careful not to allow the material you remove to fall into the camera and cause more problems.
Sep 03, 2010 | Lomo Diana Mini 586 Film Camera
I can't wind on the film, yet i can wind it back? I haven't dropped it or anything...:/
If you can wind the film backwards but not forwards, that probably means you've reached the end of the roll. So, time to wind it backwards to rewind the film back into the canister!
May 01, 2010 | Lomo Fisheye 35mm Film Camera
The winding mechanism on my oktomat is jammed how can I fix it?
First, are you absolutely sure that you haven't just reached the end of the film roll?
There are no repair manuals for this model. It's designed to last for about 12 rolls of film before it's worn out like other Lomo's in their "toy camera" range.
It's very cheaply designed and constructed and was never intended to be repaired, so if your camera is still under warranty (regardless of how many rolls of film you've shot) then make a claim. The plastic gears inside are like those on all Lomo toy cameras: awful. They may as well have just made them from cheese...
If the gears are not stripped you can try brute force by slapping the camera down onto a hard surface a few times to try and unjam the mechanism, although it risks making the fault worse. But as the camera isn't working what do you have to lose? The same applies to trying to dismantle the camera to find the fault, but you'll have to work out how to do so for yourself. Most current Lomos are simply clipped together with a minimum of screws.
If you're not covered by the warranty and cannot repair yours, then you'll need to consider whether to invest another £40 on a camera which really shouldn't be selling for more than £10 maximum.
Mar 17, 2010 | Lomo Oktomat 35mm Film Camera
My lomo fish eye camera won't keep the film in or reel it back
I have had the same problem with unloading film, i had to take the whole camera in to the shop to have them open it in a darkroom and develop the film. Seems will have to do that from now on but at least got film back.
Feb 23, 2010 | Lomo Fisheye 35mm Film Camera
Rewinding film at end of roll
Try looking here:
http://www.lomography.com/about/faq/1637-how-do-i-rewind-and-remove-film-from-my-lomography-oktomat-camera
Sep 03, 2008 | Lomo Oktomat 35mm Film Camera
Super sampler How to get film out?
once you rewind the film line up the arrows on top of the winder then gently lift the winder to release the film canister
Jun 30, 2008 | Lomo Supersampler 35mm Point and Shoot...
Photography Logo
87 people viewed this question
Top Lomo Photography Experts
Hashim Khan
Hashim Khan
Tony Parsons
Tony Parsons
Are you a Lomo Photography Expert? Answer questions, earn points and help others
