Question about Tappan Kitchen Ranges
Open the tappan range door
I turned on the tappan range forself clean and remmebered the pasn were in itand the door will notunlock
  • 537 Answers
SOURCE: Tappan electric range door locked
Check the door lock switch/solenoids. You'll have to unplug the range/stove. Remove the solenoid and check to see if it has continuity or if the solenoids are stuck.
You also might have luck resetting the clean cycle. Even though the lock is engaged, try to open the oven door a little. Start the clean cycle, then cancel it.
Posted on Dec 13, 2007
SOURCE: Self cleaning oven~door will not open
Let it cool down....
Posted on Sep 09, 2009
EllaWatson25
  • 725 Answers
SOURCE: my tappan oven self cleaning fe came up still
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
woodchuck789
  • 4070 Answers
SOURCE: can not open the door of the self- cleaning electric range.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures
rickead1
  • 1998 Answers
SOURCE: Error 43Our Bosch range will not open after setting to self clean
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Posted on Apr 30, 2010
My Tappan range will not open after I tried to run a self cleaning cycle. The cycle never ran and oven still locked.
try removing power for a few minutes and when power is applied again the unit should reset.
Dec 07, 2014 | Tappan Kitchen Ranges
I did a self clean on my tappan electric oven; cant get the door to open.... what can i do?
MaryAnn, If you try to push the locking lever/handle towards the "lock" position first, then pull it back towards the open position, it should unlock for you.
However if that doesn't work, you can turn off the breaker for the electric range, in most electric panels, it is marked as "Range" or "Stove" but is typically a double pole 50 Amp Breaker (It takes up 2 spaces). If you look at the handles of the breakers, you should be able to see the numbers "50" on the handle.
Once you turn off the power, you should be able to unlock the oven. Some ranges require that the power be on in order to unlock it, but first try to open it with the power turned off, and it that doesn't work, turn the breaker back on and the door should be able to be unlocked.
Remember that it will take a little bit of effort to get the door to unlock in some cases, so give it a good tug.
Hope you find this Very Helpful and best regards!
Oct 25, 2009 | Tappan Ovens
Stove window cleaning
refer to your use and care manual as to howe to remove your door assy, generall its open door fully and "lock " the hinges\( pull tabs on bothhingestha alloy you to "lock" thehing and upn lockking you lift the door rigth off then its a matter of removing the frame holding the glass, do it slowly and carefully the galls will coe of, clean it and revers the procedure to reinstall the door
Sep 27, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Jun 10, 2008 | Tappan TGF320 Gas Kitchen Range
The oven door of our Tappan locked accidently.We tried to cancel but there were no results.
what do you mean locked accidently if if the door is locked and 3hrs is on the display hit start then cancel if the door showes locked and is not (you can still open the door)push in on the door switch by hand and push cancel let me know
Feb 13, 2008 | KitchenAid KESC307 Electric Kitchen Range
Dec 13, 2007 | Kitchen Ranges
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Tappan tgf355 oven door won't unlock and has code f3
open the back and manually spin the motor for the latch arm it may need to be replaced
Oct 31, 2007 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
