Question about Home
I have an Ashley AP5710 Pellet Stove and keep getting an error code E1. How do I clear the code so it will turn back on.
It has only ran once since it was bought. When going to shut it off the error code appeared and now will not turn back on. I have checked for a power surge or brown out and I have checked the winding and fan blade for dust. What can I do to fix this?
SOURCE: Error code E1 -F5- Broil element comes on and wont shut off
I just did the self clean option and when it was done I received the error code E1 -F5- and it does have to do with the door latch. After turning off the power to the stove I was able to open the door and wiggled the latch and that solved the problem.......
Posted on Oct 24, 2007
jyackle5
  • 8197 Answers
SOURCE: I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Posted on Dec 18, 2008
  • 401 Answers
SOURCE: Error code shows E1 -F3- on a
F3 E1 IS THE OVEN SENSOR IT IS ON THE BACK WALL HELD IN BY TWO SCREWS IT LOOKS LIKE A ROD,MOST OF THE TIME YOU CAN PULL ITHE WIRES THROUGH OR YOU MAY HAVE TO DISCONECT FROM BEHIND
Posted on Jan 12, 2010
SOURCE: pellet stove
PRESS H THEN TROUBLE THEN START THEN HIGH 6 THEN LOW 1
THEN PRESS BLOWER & HIGH FOR 3 BEEPS
Posted on Feb 22, 2010
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Posted on Feb 26, 2010
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
My stove keeps going out on E2 and shuts down why
The E-2 Error code indicates an automatic shutdown because the stove does not detect a fire. Check out Englander's troubleshooting guide to some of the causes.
http://www.heatredefined.com/faq/troubleshooting-guide/pellet-stove/evolution-pellet-stove/evolution-pellet-troubleshooting-guide/e-codes/e-2-failure-to-start
Feb 27, 2015 | Englander Direct Vent: 2,000 sq.ft. Pellet...
WHAT DOES ER2 CODE MEAN ON PELLET STOVE
Which pellet stove do you have? A lot of pellet stoves have a part inside called a Draft Flow Switch the size of your palm and hook to the Draft Flow Switch is a Draft silicone hose and this will get clogged with debris you will need to look at your diagram to see if you have that on your stove. If you do you will need to "gingerly take off the hose and blow through it. and re connected to the draft flow Switch. After sometime the hoses become brittle. Another thing to look at is the exhaust at the back of the stove cleaned out and you are getting your pellet stove cleaned out by a chimney sweep.
Mar 03, 2014 | Us Stove Company Pellet Heater with...
Ashley AP5660L Pellet Stove
Where is the Auger Trim Button located on the Ashley stove Model ap5660L
Jan 07, 2014 | YouTube Videos
How to clear error code on ussc stove pellet 5500m
im working on a pellet stove model 6039 hf when stove is on the draft fans light stays on i cleaned very good what next
Jan 12, 2011 | Heating & Cooling
My range top is showing me E codes and I cannot get it to turn off
Range/Stove/Oven Fault Codes starting with an E
If an error code appears in the cook mode window
Your oven is equipped with an extremely reliable and accurate electronic control. On the rare occasion that something occurs that causes a malfunction, an error message will appear in the oven selector window.
Some errors (E1, E9, E11, E12, and E13) must be cleared by turning off the oven at the circuit breaker and then turning it back on. When an error remains displayed steadily in the off position, after attempting to clear the error, a service call is required.
Jan 26, 2010 | Kitchen Ranges
Home Logo
182 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
