Question about Apple iPad Tablets & eReaders
Could hook a ipad pro to my cintiq 21ux if possible how?
Is there a setting on my iPad Pro to stop my grandso from turning bright to max and will it hurt the ipad
There is a setting for 'Auto-Brightness', that measures the light in the room and alters the brightness accordingly. You could try that.
Having it on Maximum will be fine for the iPad, but not good for your grandson's eyes. It also runs the battery down much faster the higher it is.
You could just tell him he is not using it if he is going to play with settings, because at some stage he is going to set a password, forget what it is and lock you out of it, requiring a Full Reset to get you back in.
Another possibility is that his sight is impaired.
Jan 14, 2018 | Tablets & eReaders
How do you use the Apple Pen with the iPad pro
hi marilyn.
The first time you use your Apple Pencil, take off its cap and plug it into the Lightning connector on your iPad Pro. When you see the Pair button, tap it. After you pair yourApple Pencil, it will stay paired until you restart your iPad, turn on airplane mode, or pair with another iPad Pro.19 Sep 2017
Use Apple Pencil with iPad Pro - Apple Support.
How do you use the Apple Pen with the iPad pro Google Search
Nov 01, 2017 | Apple Tablets & eReaders
I have an apple ipad i dont have a passcode or a computer to hook up to how do i factory reset it
Ask someone you know who does have a computer if you may hook up your iPad to it. Then follow the instructions here:
https://support.apple.com/en-us/HT201252
Oct 29, 2016 | Apple Tablets & eReaders
How can I transfer music from a flash drive like leaf bridge to my iPad Air and then have that music stored in iCloud?
You can attach some flash drives to Apple's $29 iPad Camera Connection Kit. (If you have an iPad with a Lightning connector you'll additionally need Apple's $29 Lightning to USB Camera Adapter.) Let me underscore some. Some flash drives require more power than the iPad can provide and won't work.
For the second question, here's also a guide to help you back up iPad music to iCloud.
  1. Connect your iPad to a Wi-Fi network.
  2. In iOS 8 or later, tap Settings > iCloud > Backup. ...
  3. Make sure that iCloud Backup is turned on.
  4. Tap Back Up Now. ...
  5. Make sure the backup finished by tapping Settings > iCloud > Storage > Manage Storage, and then select your iPad.
If you have a new computer, you can also backup iPad music onto it.
http://www.leawo.org/tutorial/how-to-sync-iphone-to-new-computer.html
Apr 11, 2016 | Apple iPad Air
How can one replace the battery
If it is even possible to get a replacement battery, getting to the battery will most likely require a small Philips screw driver and possible plastic pry bars to remove the rear bezel. You can use the iPad repair guides here as a reference, plus all required tools can be purchases here. Repair Manuals for Every Thing iFixit
Nov 07, 2014 | Visual Land Prestige Pro 7D 7 inch Tablet...
Why doesn't the touch work on my ipad
The iPad's touch screen should always work, unless it froze. Try and restart the iPad (hold down the button on the top edge, close to the camera lens until the iPad turns itself off, normally a few seconds). If it doesn't work after a restart, you may need to reinstall the system, which you can do from iTunes (attach the iPad to your computer, open iTunes and choose 'Restore iPad' - you need internet connection to download new system). Have iTunes back up your iPad before restoring it, if possible, or data will be lost.
If none of this is possible, you may need a repair at a service centre. Good luck! :)
Aug 18, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad will not trun on. tried hooking it up to the cumputor and hit both volume and on button at the same time but no luck.
I had this problem with my iPad mini. In search the web, it was said the output of some computers were insufficient to charge the device. I tried plugging it into a USB wall adaptor and after a few minutes, it powered up. If you do this, don't expect it to power up for a few minutes.
May 31, 2014 | Visual Land Prestige Pro 10D 16 GB Tablet...
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    I purchased Pages using the safari on the ipad. When I tried to install it on my ipad, I got a message saying that I need to open itunes on my computer. So I did. Then I downloaded Pages onto my computer....
    Now you have to sync your iPad with your computer. With the 30 pin to usb connector that came with your iPad. When you hook up your iPad to your computer iTunes should automatically pop up with the iPad sync page when that happens choose sync from the page and wait until it's done.
    Jan 12, 2011 | Apple iPad (16 GB) WiFi Tablet PC
    Android on apple Ipad, is it possible? that might be an interesting thing to do I guess. if you guys here have any idea then please let me know how to do it
    It is not possible android runs on a different platform then ipad
    it is not possible without rewriting the whole software from scratch
    hope this helps
    Feb 11, 2010 | Apple iPad 16 GB 3G Tablet PC
    Tablets & eReaders Logo
    22 people viewed this question
    Top Apple Tablets & eReaders Experts
    Virgil Wolter
    Level 1 Expert
    Aaron Galvan
    Level 1 Expert
    John mullen
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
