Question about Video Game Consoles & Games
Started beeping replace batteries two days later started again.3 beeps every 40 seconds.
SOURCE: My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Posted on Nov 18, 2009
bmckeon
SOURCE: Cbyer power 525Sl keeps turning off and on and beeps.
I have the exact same issue with my 525SL.
When you push in the red button - the green power light comes on for about 5 seconds = then the light goes out and the device plays a single long beep for about 5-8 seconds.
Given the dialogue here - I took out the battery and bough a brand new BB replacement battery and returned it into the unit as it should. The device continues to have the same behavior.
So it is NOT always a new battery that will fix the system.
Don't jump into spending $30.00 for a replacement.
Look into this further or you'll wind up wasting your money.
Posted on Dec 30, 2009
SOURCE: Powerbolt 1000 started beeping and quit functioning
To provide a further bit of information. According to tech support the beeping can be caused by EITHER a bad keypad (about $15) or a bad circuit board (about $80, so, time for a new lock). The easiest way to tell is to:
  • Remove the batteries
  • Unscrew the circuit board from the housing (it will remain attached and dangling by some wires)
  • Unplug the gray ribbon cable that connects the back of the circuit board to the keypad
  • Put the batteries back in
After powering back up, if the unit keeps beeping, the circuit board is bad. But if it doesn't the keypad is bad. You can order the replacement keypads from Weiser via the 800 number listed in the previous comment.
Posted on Apr 15, 2010
  • 4736 Answers
SOURCE: smoke alarm beeps 3 times so I changed the
It may be clogged with dust. Remove the cover and blow it out with canned compressed air, like you clean a computer with.
Posted on Jan 15, 2011
  • 963 Answers
SOURCE: Began to beep in intervals.
Why is my Powerbolt 1000 unit beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Posted on Sep 23, 2011
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
Ps3 will not start up only goes to a wave yellow line
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Swapped ps3 (1 day old) from hdmi connection on telly in lounge to telly in another room on scart and no picture!! Disc is 'whirring' nicely, lights are on but nothing on av channel??? Any suggestions?...
You need to reset the display back to standard definition. Please do the following steps:
Step 1. Turn the PS3 off into standby mode ( red light on )
Step 2. Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the PS3 to start
Hope this helps
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has stopped showin the icons but its loading up the front screen is there but no icons ?
Your software needs re-installing, follow this procedure :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and switch off back into standby mode (red light on)
Step 3. Press and hold the power button again. It will beep when you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then move onto the next step.
Step 5. A menu will load up with 6 options. Choose option 3 first "Restore File System" and go through this process. If this does not work do the above but choose option 4, then as a last resort option 5. A warning though, option 5 will erase all your data on the hard drive.
Hope this helps and thank you for using FixYa
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
Hi,\r\nPlaytstation 3 will start up (logo and sound will come on) but no menu appears ? please help Thanks John.
Ok, this unfortunately means that your PS3 software has become corrupt. The only way to fix this is to completely restore it. The only problem with this is you will lose all of your saved games.
Follow these simple steps :-
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later then beep once more and turn back off into standby. Release the power button
Step 3. Press and hold the power button again. It will beep as soon as you press it, then 5 seconds later, then there will be 2 quick beeps together. Let go of the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via the USB and press the PS button. Do this and then move onto the next step.
Step 5. A menu will load with 6 options. Choose option 5 "Restore PS3 System". Go through all the prompts and accept everything. This will format your hard drive and replace the PS3 operating system. When the PS3 next restarts it should all be back to normal.
Sep 08, 2010 | Sony Playstation 3 (PS3) Console
CANNOT START THE CORRECT HARD DISK WAS NOT FOUND
To solve this problem follow these steps :
Step 1. Turn your PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then beep once more and turn off into standby again. Release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then 5 seconds later beep again and then there will be 2 quick beeps together. Release the power button when you hear these 2 beeps.
Step 4. The PS3 will start up asking you to connect your controller via USB and press the PS button. Do this and then continue to the next step.
Step 5. The recovery menu will load. Select 3 "Restore File System". This will rewrite the hard drive system and hopefully get your PS3 working again. You shouldn't lose any save game data but that is not guaranteed. Ignore any messages about the hard drive being corrupt.
If the above method does not work try steps 1-4 again but select option 4 from the recovery menu. If that doesn't work as a last resort select option 5. Selecting this option WILL erase your data!
I hope this helps and thank you for using FixYa
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
I have a playstation 3 system that worked for 1 day & the next time i attempted to play it,it did nt go past the initial playstation intro screen.The screen is grey with the playstation wave symbol...
Ok, follow these steps to cure your problem. Warning, you will lose saved game data!!
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep when you press it, then beep 5 seconds later and then once more another 5 seconds later and turn off. Release the power button.
Step 3. Press and hold the power button. It will beep once when you press it, again 5 seconds later and then 2 quick beeps together. When you hear these 2 beeps release the power button
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then continue to the next step
Step 5. The options menu will display. Select option 5 "Restore PS3 System". The PS3 will re-install the software required and restart. Hopefully this will solve your problem
Hope this helps and thank you for using FixYa.
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
I have the model 0916. It beeps every 40 seconds
Manufacturers recommend replacement every ten years. Could be dirty? Is it connected to the ac house power?
Aug 03, 2009 | Kidde 0914 Battery-Operated Ionization...
I have 3 of these alaems and 1 keeps beeping
Replace all batteries with the exact make and model listed on device.
Jul 12, 2009 | Kidde 0914 Battery-Operated Ionization...
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
