Question about Coffee Makers & Espresso Machines
Salad Master Coffee maker. How much coffee for each cup? Also how do I keep grounds out of coffee? Thanks Aimee
  • Coffee Maker... Master
  • 16,777 Answers
A machine like the one in the link? That is an old style percolator. Mother had one when I was a kid. I am 63!
You will see in the diagrams that a filter paper is being used. With mother's the bottom of the strainer was fine so you didn't need one. Use a standard bowl type filter and if you can find circular filters with a hole.
One heaped dessert spoon is two cups. Supermarkets have a measure for sale.
Salad Master Coffee maker Google Search
Posted on Dec 19, 2016
SOURCE: coffee maker won't start and just beeps when plugged in
The door on the top is not closed properly. When you open the top door(cover),you will see a button that is located on the top of the grinder cover. that is a switch that tells the coffee maker that the door is closed and can safely make coffee..please check that all parts are in place and top door(cover) is closed comepletly. good luck.
Posted on Jun 26, 2007
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
  • 2976 Answers
SOURCE: How does it make coffee?
You fill it to the line indicating how many cups of coffee you want to make. Then you add coffee to the brew basket, at least 1 full heaping teaspoon per cup. Put the basket on top of the stem and place the stem into the coffee maker. Put the lid on and plug it in. That's it. Don't plug it in without the lid, it's a percolator. It will squirt the water out the top of the stem and it flows down through the coffee grounds.
Posted on Jan 04, 2009
  • 59 Answers
SOURCE: How much coffee grounds for a 22 cup west bend
We use 2 1/4 cups for a full 36 cups. A fraction under 1 1/2 cups is good for 22 cups.
Posted on Nov 27, 2009
EsWorld
  • 1618 Answers
SOURCE: grinding and dumping coffee without making a cup.
Check the grind it might be too fine, then check the screen under the red o-ring in the brew unit it might be blocked.
Posted on Feb 26, 2010
How to make stronger coffee
West Bend recommends 2 cups of (medium coarse) ground coffee for 36 cups of coffee. It also states that theses measurements are for mild coffee. Add another 1/4 - 1/2 cup for stronger coffee. Keep adding more until it meets your liking. Here's the link to the manual for model #58036. http://www.manualslib.com/manual/337763/West-Bend-58030.html#manual
May 15, 2014 | West Bend (58036) 36-Cup Coffee Maker
Saladmaster jet o matic percolator coffee maker manual
I need to find a thermostat for salad master 6 to 10 cups
perculator. Have any idea where I an purchase one.
Dec 13, 2011 | Coffee Makers & Espresso Machines
How much coffee do you put in for 100 cups? thank you
I can't say how much cups but if you want to make 60 ounce coffee Then you need 3.25 ounce ground Dunkin coffee Let 10 ounce each cup so for 100 cups you need 1000 ounce coffee. For that (3.25*1000)/60. =54 ounce ground Dunkin coffee Thanks Please rate my work I gave you a very good answer
Sep 08, 2011 | West Bend 33600 Coffee Maker
How many coffee scoops do i use for 30 cups and 36 cups
The Instruction Manual for your coffee maker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
Instructions include the following:
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Aug 02, 2011 | West Bend (58036) 36-Cup Coffee Maker
How much ground coffee should I add to my West Bend 58030 Coffee Maker to make 30 cups of coffee?
For 30 cups of coffee, use 1 ¾ Cups of ground coffee for mild coffee. If you like a stronger brew, add more ground coffee.
Retrevo has the manual for the West Bend 58030 here: http://www.retrevo.com/support/West-Bend-58030-Coffee-Makers-manual/id/4210ag322/t/2/ . You will need to enter a code to download the pdf.
I hope this helps.
Jun 10, 2011 | West Bend 58030 Coffee Maker
How do you use it?? just like a reg coffee maker only with no glass carafe?
Yes, it works just like a regular coffee machine, like mr coffee, but instead of using 8 or 12 cup glass craft, it makes one cup at a time, put coffee grounds in to your desired strength , put water in container and put cup under and have a great cup of Joe. Thanks Mr Bean
Jun 09, 2011 | Hamilton Beach BrewStation 47214 Coffee...
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
See page 4 for amount of coffee to use.
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
Coffee maker won't start and just beeps when plugged in
Aug 19, 2006 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
