Question about Crosman 3576 Revolver Air Pistol
We have a 22 long S&W # 1K47316 Pearl Handel Grips how old is it and how much is it worth. Thank you
I need a handel for pressure cooker brand is jasi and the handel i need is for the pot thank you.
Fixya does not sell pressure cooker handles. Check with a local appliance parts supplier.
Nov 14, 2016 | Home
What is the date of mfg?
from description about .50 cents words are worth very little
Mar 11, 2015 | Optics
I put on new grips. Now my throttle wont release on its own. I have a 1994 honda shadow 600 vlx. Can you please tell me what the problem might be. Thank You
Trim your grips off the handlebar part of the throttle ... your grips are overlapping and holding the throttle open ... a very dangerous situation.
Thank you for using
Sep 27, 2010 | Honda VT 600 C Shadow Motorcycles
There's no delay start on our new Miele W3740 washing machine. Can we use an electronic timer in the plug socket to delay the program start (cheap night-time use of electricity)? Thank you. Gerald
yes you could use a delay plug if it dont over rate the plug,,,check how many watts your washer pulls and how many watts the delay plug can handel first,,,if its more than the delay plug can take dont try it or you may just have a fire on your hands,,
even with cheap electricity is it worth that?
Nov 20, 2009 | Washing Machines
When i install a new battery it comes on shows pearl and shuts off it did this before it has happened to another one
i bought a different one the other one wasnt worth fixing it would cost me more than i paid for it thank you anyway
Oct 19, 2009 | RCA TH1611 MP3 Player
Hood latch cable malfunction. Interior handel broken.
use a small pair of vice-grips, ajust to clamp very tight, then pull
Jul 27, 2009 | 2000 Ford Taurus
The drivers door handel
Yes, you'll have to remove the interior panel to assemble the linkage for the handle.
If you don't already have a panel removal tool, I'd swing by your local parts store and pick one up. They're normally around ten bucks and will save you from damaging your panel (sometimes they can be a bit tricky on these Explorers).
Hope this helps and good luck!
Jan 13, 2009 | 2001 Ford Explorer Sport
Broken handel (Wire snaped)
Cables Broken In your Handle ???? Please visit as we specialise in the repair of Quinny/Maxicosi Mura/My 3 -4 Handles,Grips-Cables Repaired
Dec 16, 2008 | Quinny Buzz Jogger
Sunbeam Food Processor/Le Chef 14-11, 14-1A
My mom gave me her Le Chef that had several cracks in the handel and also the place where the handel attaches to the bowel with a screw was broken. I Used Loctite super glue for the crackes in the handel and a loctite epoxy putty that can be molded into the shape needed to fix the place where the screw attaches the handel to the bowel. After the putty set I sanded it to refine its shape and matched the screw hole in the bowel with the handel then drilled a small polit hole in the handel. I slipped the handel into the slot in the bowl and attached it with the screw and now I have a good as new Le Chef.
Jun 23, 2008 | Food Processors
Crosman 3576 Revolver Air Pistol Logo
111 people viewed this question
Top Crosman Sport & Outdoor - Others Experts
Are you a Crosman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
