Question about The Watches
How to remove the plastic between the stem and the case-how do you remove this plastic
    Top Expert:
  • The Master
  • 40,764 Answers
Simply pull the plastic tab out
then push the crown back in
the battery is energized when the stem ( crown) is pushed all the way in
it is used to stop the crown from making contact during storage before sale so ensuring that a new battery is installed on purchase
Posted on Dec 19, 2016
I opened the package and dont know how to turn it on!
mcdevito75 Here, It must be a Quartz watch, look for a very small piece of plastic just under the stem, remove that piece of plastic, push the stem down and your watch should start. OR!! look on the back cover of your watch, carefully, if you see a plastic tab comming out of the back cover, remove by pulling carefully on that plastic tab, this plastic tab is keeping the battery from grounding, thus saveing battery power but also not letting your watch run. Simply reove this tab by carefully pulling on it.
Jun 17, 2011 | Watches
How do i remove crown?
hummmmmmm
u need to go experts of watch reper i think its its problem in watch curcuit thats y this happen
& thnx useing fixya
Mar 28, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
I pulled the entire crown and stem out of my Rolex President. What is involved in fixing it?
The repair for this problem may be quick and inexpensive--or somewhat more expensive. Either way, it's considered a minor repair.
The crown and stem assembly in held in a Rolex movement by a small pressure screw. When this screw is loosened, the stem can be cleanly pulled out of the movement without damaging any parts. The movement can then be removed from its case. If the screw is too loose, it is sometimes possible to pull the crown and stem out with ordinary effort. The simple fix for this would be to have a watchmaker take the back off your Rolex (requires a special wrench) and slide the stem back into the watch while loosening and re-tightening the screw. If that's it, the repair takes about 5 minutes, most of which is spent removing and replacing the watch back.
Things can get more complicated. The set stem interacts with a thin sheet metal spring / detent that helps the stem "snap" to its various set and wind positions. Sometimes, when a stem gets pulled out, the force of that can snap the delicate little finger in this watch part. Replacing this watch part will require that the movement be removed from the case and the hands and dial be removed for access to the part. Once you get to it, the part itself can easily be replaced--it's designed to be replaced without disassembling the whole watch movement--but there's considerably more effort involved than just sliding the stem back in and tightening down the screw.
May 08, 2011 | Watches
New watch - how to start it - battery?
mcdevito75 here, Brand new watch. If it has a stem, (winder) look for a small piece of plastic between the stem and case, remove this piece of plastic and push down the stem to start your watch. If your watch is all buttons, look for a small plastic tab on the back cover, remove this plastic tab and your watch will start.
Sep 20, 2010 | Adidas Response Light Twin watch #ADP1701...
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
It is a new watch. How do i start it
mcdevito75 Here, If It"s brand new just out of the box, Check just under the stem knob (winder) for a piece of plastic, remove the piece of Plastic, this will allow the stem to fully seat and start the watch.
Jun 13, 2010 | Citizen Calibre 2100 AV0031-59A Wrist...
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
Apr 04, 2010 | Watches
Illinois pocket watch stem removal.
First you must say what type as there are differences depending on the mfg and model.Be the following basics apply.
1- Put the stem in the setting position (usually pulled out if stem set).
2 Them open cover to expose the movement. ( Screw off or snap open).
3- Remove the movement (Usually held in place with 2 screws at the outer edge.
4-Then if there is a screw in the part that holds the stem loosen that.
5- The stem can be held with a pair of pliers on the flat and the crown unscrewed. Be careful not to damage the square (FLATS), with the pliers. A rag or other safety measure should be taken.
6- then inside the stem hole, looking from the ouside the is an annular area around the stem that has a ferrule screwed into the case this has to be unscrewed and will bring out the stem and the ferrule.
This siounds complicated but the steps are more involved to write than they are to perform.
There are many variations to this process, and each type should be understood before proceeding.
mrmel.mrmel@gmail.com
Dec 15, 2007 | Watches
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Watches Logo
Top The Watches Experts
John mullen
D. E. Hev
 Larry
Larry
Are you a The Watch Expert? Answer questions, earn points and help others
