My garrad 100c turntable cuts on when I switch it on but cuts off when the needle touches the record. what would cause that?
  • Audio Player... Master
  • 17,115 Answers
Very good article here: http://www.ortofon.com/support/support-hifi/faq-installation
Shows the connections on the back of the stylus.
Posted on Dec 19, 2016
The start and cut switches do not seem to work I have it open and the wires do not seem to be attached to anything
Aiwa lid close control switch Turntables Questions ... - Fixya
www.fixya.com > Forum > Tags > lid close control switch > Turntables
Aiwa turntables lid close control switch related questions and answers. Ask your Aiwa... Ad. Question about PX-E860 Turntable ... aiwa lx 70 turntable needle arm My aiwalx 70 turntable is not working. I can power it up, and when i press the start/cut button the platform rotates, but the needle arm does not move to play the .
Aiwa fusing unit Turntables Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fusing unit > Turntables
the drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on Lift... the start/cut button the platform rotates, but the needle arm does not move to play the . ... will not turn,belt o/k fuse o/k Check any switches to see if they work.
Jan 16, 2016 | Aiwa PX-E860 Turntable
Scratchy sound on turntable with mat om
One of two things. The deck has got a static problem. Perhaps caused by an earth connection problem.
Or you have a bad earth connection on the cartridge.
Dec 27, 2015 | Crosley Executive Portable USB Turntable
Denon dp200usb skips new records
Do you have a a weightscale for the needle pressure, anti-skate right and the table straight. An overhang gauge and set the needle in the right angle. If that't ok make sure the record and needle is real clean, since you often don't see that piece of does which causes it.
Apr 16, 2014 | Denon DP200USB TURNTABLE W USB Turntables...
Needle sliding
Going on what little you have written, the most likely cause is a worn or bent needle. http://www.turntableneedles.com/search.asp?keyword=793-d&search=GO is the needle type that should be correct for your Teac SL-A100 Turntable.
Feb 16, 2013 | Teac SL-A100 Turntable
My turntables needle slides to the end of the record without playing.
is the stylis touching record.
what turntables have you got?
Aug 09, 2009 | Audio Players & Recorders
No sound coming from turntable
most likely this is the switch that selects among cd/tape/radio/record player. it could be the preamp circuitry in the player as well. it would not be the cartridge UNLESS you cannot see a little rubber 'seat' up inside underneath the cartridge that pushes the stylus tip out and down towards the record just a bit. if this rubber 'yoke' (seat) is missing you will get no sound even when you touch the needle tip when the record player section is selected.
Jan 29, 2009 | Crosley CR248 Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
1210 problem
Those are just standard phonograph player characteristics in my experience. You'll hear a tap on the deck because there's essentially a live mic ( the needle ) physically coupled with the record on the turntable and the rest of the phonograph player even though they try to dampen the coupling of the turntable as much as possible. The rumbling noise at high gain is because the turntables being driven by a motor via gears or a belt and creates some  vibration, wich is transmitted through the turntable and picked up by the transducer ( needle ), low frequency rumble, just like a recording studio on a busy street may pick up from road vibration/ noise.
Aug 06, 2008 | Technics SL-1210 Turntable
57 people viewed this question
 Grubhead
Grubhead
