Getting on line. - Computers & Internet
  • Computers & ... Master
  • 18,271 Answers
Why can't you get online Donald? Where are you trying to get to, what do you do and what happens?
Reply as COMMENT under my post.
Posted on Dec 19, 2016
I have a Poulan Pro leaf blower/vac. The fuel lines cracked inside the gas tank so I pulled them out & bought new ones. Now i can't get them back in to the gas tank. I understand there are
Make sure that you have the right size lines the smaller diameter line goes into the bottom hole of the tank cut a 45 angle at the end of the line as you put the line into the tank twist and push until you get enough line to pull up through the fuel filler hole then cut the line so that the 45 is no longer and slip the fuel filter on then pull back the line until the filter rests at the bottom of the tank. Do the same with the upper line except that line will only go in 3 to 4 inches. I hope this helps you.
Feb 29, 2012 | Poulan Pro Gas BlowerVacuum ()
What is the diameter and length of a 1996 Toyota Corolla brake line?
3/16S OR 1/4 inch but you can't get prebent brake lines you need to make them . You can get the line its cheap enough however if you have a rotted line the best way to handle is to cut out the bad area then you can get short lenghts of line that have fittings and flares on them NAPA has them . So cut the old line after the rot get a peice of line as long as you need you can get 8 inches up to 6 feet . Go right from the fitting on the cylinder or caliper to the cut them you need a cupler the hardest part is you need to put a flare on the old line that you cut witch means you will need a flareing tool there about 30 dollars slide the new fitting on the line flare it . Then it all threads together and is a perment fix bleed the wheel likely the drivers side rear and your good to go
Feb 12, 2011 | Toyota Corolla Cars & Trucks
Rear brake line rusted out between axles 95 eldorado, wondering where to get parts
you will have to go to auto parts stor. buy replacement line and make new line also get new fittings. or you might can get a used line from a salvage yard CADILLAC PARTS DOES NOT HAVE REPLACEMENT LINES
Aug 22, 2010 | 1995 Cadillac Eldorado
BIS-10 Phone - How to change default line
If you have a "squared" system (each line assigned to a different button), just press a different line button. To change the order of the lines, slide the "T/P" switch to "P" and press the line buttons in the order you want to use them (ie: Line 4, Line 3, Line 2, Line 1).
If your lines are "pooled" you just get the next available line from the pool - no choosing which line you get.
Hope this helps.
Jun 21, 2010 | AT&T Merlin BIS 10 Phone
Can not get kx-t7885 to get a dial tone. The phone is paired with it's base, and will get the panasonic dial tone but not an outside line.
How are you trying to get an outside line? By dialing 9? If the host system happens to be a TA series, you have to tell it how many lines you have, or that you don't have lines that have hardware ports but no dial tone, since systems select outside lines from the top down.
From System programming, program 400 defines connected lines.
Nov 22, 2009 | Panasonic KX-T7885 Cordless Phone
Install new fuel line
This is usually pretty easy. Most of these lines are plastic. Many hardware stores have various diameter-sized lines. Make sure you get the right size.
The usual difficulty is getting the line out of the gas tank. There is probably a filter and/or weight at the end, and these must be removed. The line should then pull out. Getting the new line back in can be more difficult. Cut the new line into a v-shape lengthwise and then try inserting it.
Oct 18, 2009 | Garden
Rear metal brake lines
To get the length, just get a roll of string, run it along the existing brake line 'til u get to the rubber line. you can cut off the line near the master cylinder, bring it to the parts store, they can tell you what size you need. You will have to use several lengths of line to reach the back. If this line has rotted thru, you should change all the others, as they are likely to fail soon. countrycurt0
Aug 20, 2008 | 1998 Jeep Cherokee
Phone line splitters
Your jack probably only has one line installed on it, therefore you only get one line. Have you checked to see if the jack has more than one line installed?
Jul 22, 2008 | Lands Phones
Siemens Gigaset 2420 tow line phone system
Contact 888-286-9375 Siemens Repair Line. Should be able to help you.
Jul 21, 2007 | Siemens Gigaset 2420 Cordless Phone
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
