Question about Cameras
Why are my card not working? - Cameras
  • kakima Dec 19, 2016
    Hi Christine Mary Murray, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model camera? What type and capacity card?
What type sandisk mirco sd cards work?
You didn't buy a microSD card, you bought a microSDXC card.
The Eclipse 180 works with microSD cards (2GB or smaller) and microSDHC cards (32GB or smaller). It does not work with microSDXC cards.
Jul 26, 2014 | Mach Speed Eclipse 180 MP3 Player
I have a digimax 4010. Do I get a 2mg sd card? What is the diference between a sd card and a sdhc
SDHC is an extension of the SD standard that extends the capacity from 2GB to 32GB. It's backward compatible in that devices designed for SDHC cards will also work with SD cards. It does not go the other way---that is, SDHC cards will not work in devices designed for SD cards.
I presume you mean a 2GB card, since a 2MB card might hold one picture.
The Digimax 4010 works with SD cards, not SDHC cards. You may use an SD card. Just make sure it is an SD card, 2GB and smaller. SDHC cards start at 4GB and go up to 32GB but, as stated earlier, will not work in the 4010.
May 25, 2011 | Samsung Digimax 4010 Digital Camera
I just bought a new verbatium 8 gb SDHC memory card for my Pentax S6 camera and it does not work powers on but can not get menu funtions to work. my old card is a SD 1GB works fine are the new SDHC cards...
No. The S6 works with SD cards, not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work with devices not designed to use them. You need to use SD cards, 2GB and smaller.
Apr 17, 2011 | Pentax Optio S6 Digital Camera
How to formmat sd card for wii? i did it in my laptop but next day it changed back so i formmating again and same happened. how could i formmating permenant? this is 4gb memory card. thanks! tammy
I don't think that all memory cards work on the Wii. I had problems with some new SD cards to because I tried four new memory cards. The card specifically for the Wii worked, along with the Wii PowerSaves card (like action replay) but two picture memory cards did not work. I think only some cards work because on the nintendo website, it says that only Nintendo licensed SD cards work so... sorry.
Aug 27, 2010 | Nintendo Video Game Consoles & Games
I can't get my sd card to work in the computer. Do I need something to make it work.
No you don't need something to make your sandisk(sd) card to work when you place it in the sd slot of your computer, now if your sd card is a hc or high compacity card then it would not work because the sd card reader is not new upgraded enough to the point of reading the hc cards if its not a hc card then your sd card reader may be broken you can buy a good new sd card and more port hub to work on your computer but i would check first if it is your card not the card reader.
Feb 10, 2010 | Computers & Internet
I put memory card into a card reader and it got stuck and now memory card doesnt work
1. You have removed the memory card forcefully from the card reader, that's why it not working!
2. Does the card reader detects your memory card (even if it's not working)?
3. Check your memory card with a digital camera / card adapter!
please rate this advice if it! :)
Jan 13, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
Centros Secure Digital Card Reader Model No.4418951 will not read a SanDisk SDHC Card 4GB.
1. Safely remove the Card and Card Reader from your system.
2. Plug in the Card Reader to the system.
3. Now, insert the Card in the reader.
4. Let the system take some time to detect the devices.
* If the Card Reader donot read the card, try another card to check if there is problem with the reader or card!
* If the Card Reader still donot detect, check it with another system.
tell me if it! :)
Dec 31, 2009 | Computers & Internet
Sometimes the card and the camera (any camera) won't get along. If another card works in the camera: Try formatting the card in your computer first and try to read it. If it doesn't work there, replace the card. If it works, then put it in your camera and try formatting. It should now work.
If another card does NOT work in the camera: You may have a problem with the camera's card reader port and may want to call Kodak for help.
Jul 07, 2009 | Kodak EasyShare C330 Digital Camera
PED-Basic Memory Card does not work anymore
my brother embroidery has quit working and I do not know why. A message comes up on my machine saying, "this embroidery card can not be used. Unusable cards include carded licensed for sale in other countries. No embroidery pattern. I have used this card many times in the past
Jan 04, 2009 | Computers & Internet
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
