My sm elec. rm heater is out but the fan still works, How to fix it ?
Heater / ac fan will not come on
i THINK YOUR TALKING ABOUT YOUR BLOWER MOTOR. TO CHECK THAT JUST UNCONNECT THE ELEC CONNECTION CHECK FOR 12V WITH KEY AND SWITCH ON. IF VOLTAGE IS NOT THERE CHECK MAXI FUSE IF IT IS THERE AND MOTOR ISNT WORK IT MUST BE REPLACED. OLD TRICK TAP ON THE BLOWER MOTOR WITH KEY ON AND SWITCH ON AND IT MIGHT COME ON THATS NOT A FIX BUT WILL KEEP YOU WARM UNTIL YOU GET ONE
Feb 11, 2010 | 2000 Buick Century
Reset button keeps tripping, water gets too hot,new elements did not solve problem, can it be fixed or does the water heater need to be replaced?
replace the thermostats, be very careful!!!! thats 220volts for elec water heaters, 220volts kills you if you touch it wrong,.....it is one thermostat but it's best to match them, so you'll need both,...not expensive. good luck, cracklin joe
Jan 07, 2010 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
My jeep died on me last night. When I got it home and looked under the hood my right side elec fan was completley gone(shattered) and the fan that bolts to the motor in front of it only had one nut left...
I dont have any pics but yes you can reuse the fan if its in good or reusable condition. The electric fan you need for when you turn on your AC it works with your AC.
Dec 05, 2009 | 1998 Jeep Cherokee
1989 chev sub. heater fan will not operate,
yes under hood or dash if fuse is good check your elec. plug on heater fan housing may be burned up replace plug if still bad fan motor is no good
Oct 18, 2009 | 1989 Chevrolet Suburban
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
Atwwod 10 gal gas/elec water heater won't work on elec.
THE LIGHTED SWITCH SHOULD BE THE 12V ENERGY SOURCE TO ACTIVATE THE LP SIDE OF THE HEATER. THERE SHOULDN'T BE A LIGHTED SWITCH FOR THE 110 SIDE. THERE SHOULD BE A SWITCH OR A COMBINATION OF SWITCHES. ONE ON THE WALL LIKE A LIGHT SWITCH AND ONE MOUNTED BEHIND THE HEATER.
Jul 07, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hyundai coupe r/h drive heater
hi from uk your heater fan problem is most likely to be what is known as the resistor pack sometimes called the reostat and is connected to fan motor case it has the wires for fan connected this unit operates rather like an elec hob controlling amount of heat if this simplifies it for you? speeds 1 2 3and 4 gives the speed selected on fan control knob not too difficult to find and diy a replacement? and not too expensive ? these units do burn out occasionally on most cars as they age hope this helps/inspires ?
Jan 08, 2009 | 2000 Hyundai Accent
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
