Question about Sewing Machines
Stitches too small
Not new to sewing, have tried all stitches and can not seem to get a fair size stitch, all really small
  • Sewing Machines Master
  • 10,221 Answers
If it's an older mechanical machine, there's a good chance the oil has dried (turned to brown glue gunk) and is binding the moving parts of the machine. Even the selectors and dials can be affected. Mechanical machines do need thorough cleaning and oiling with a good quality oil (NO WD-40, cooking oil, old-stinky sewing machine oil).
Wheel on right side that controls the needle up and down is very tight...
Posted on Dec 19, 2016
    Problem Solver:
  • 22 Answers
TIP: A general rule of thumb is that if the stitch looks bad on the top it is the bottom tension.
If the stitch looks bad on the bottom it is the upper tension. The upper and lower threads play
tug of war with each other.
Tension
You need correct tension on the top and bottom threads, but you must also have correct tension on
the quilt held between the rails. You should have a small amount of "sag" in your fabric. This allows
enough movement of your quilt layers for the needle to penetrate and make good stitches.
Before you start making adjustments to your machine ask yourself, "What changed?" If your machine
was stitching great and all of a sudden it has loopies on the back or puckers, "What changed?" Did
you just change the bobbin? Did you just lift the take up rail? Did you lower the take up rail after
finishing your last quilt? Did you recently change the needle? Did you just roll the quilt?
If the take up rail with the quilted portion of your quilt is too high, it will result in poor stitch quality. You
need a finger tip space between the quilt and the machine bed. Higher will result in poor stitch
quality, too low and the quilt will create a drag on your machine's movement.
Look at your bobbin, a sloppy wound bobbin will not create a good stitch. Make sure that the threads
on the bobbin are snug and evenly wound. Check to see if there is a piece of lint in the bobbin case
Can janome machines stitch names on material
no it would have to be an embroidery machine
Mar 23, 2017 | Janome Sewing Machines
How do I change stitches on silvercrest sewing machine model875ouk
Do you mean the size of stitch or the type of stitch ?. Size is usually controlled by a dial with numbers on it, or a lever with numbers on it. Metric machines will have stitch sizes in millimetres, or 'mm', so maybe 0, 2,2.5, and so on. Others will have stitch sizes ranging from 0 to 20 per inch, with increments including 8, 10, and 12.
If it is the type of stitch, again, usually a dial controls this. It may have symbols on it, that resemble the stitch. Zig zag for example, nearly always indicated by Z shapes. If you have a pic of the machines front, fairly close up , I could tell you more. Some dials need to be pushed in to work, some need to be pulled out.
Oct 09, 2014 | Sewing Machines
Singer sewing machine
Only a sewing tech can tell you:
If the feed dog height is too low, you have to get it serviced.
It the feed dogs are worn out, you can buy them and put them on yourself, but the repair shop would probably attach a new set while you wait with no labor charge.
Mar 06, 2014 | Singer 2638 Mechanical Sewing Machine
I cannot get my monogrammed letters to come out clear. what am I doing wrong?
Are you using interfacing or "stich and sew" type support under the fabric?
To get a good result you need to interface the fabric, and use machine embroidery thread to get a silky look to the stitching. If you are stitching onto linen then you can use a tear away stabiliser and go for a small sized needle, probably size 70.
Some machines may have a fine "stitch density" adjustment too that will allow you to stretch or close up the stitching to finesse how it looks.
However, if it seems to be missing/not fully catching the lower thread in some stitches, then your timing may be slightly out. Will it sew a wide zig zag okay?
Timing is probably best adjusted by a technician so if you try the above and its still not looking good, then take it for a service.
Oct 10, 2011 | PfaFF Creative 7570
I am sewing a knit fabric on my Lily 540 and it is skipping stitches like crazy. I have tried adjusting the tension and the stitch length with no success. seem to always have a hard time with getting even...
It sounds like you may be using the wrong needle. For knit fabric you need a ball point needle in order for it to sew correctly. A regular sharp type needle can cause the stitches to skip. Also make sure you have the right size for the type of fabric. Lighter weight fabric needs smaller size needle and thicker types need bigger sized needles.
Also make sure you have the right presser foot and the right pressure on the presser foot to get nice even stitches. A roller foot helps when sewing knit fabrics.
May 18, 2011 | Husqvarna Lily 540 and 550
Bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Jul 27, 2009 | Bernina Virtuosa 160
Size of stitch
Sounds like malfunction with the feeddogs or stitch length balance. Without thread or fabric, turn the handwheel and watch the feeddogs (the toothy looking things under the presser foot which moves the fabric as you sew). The amount of distance they move with each revolution of the handwheel determines the stitch length. Watch to see whether they move from front to back. It may be that they are worn out or that they are just too low to adequately move the fabric as you sew. Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Jun 11, 2009 | Husqvarna Viking 1
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
