TV turns on for 1 min then off, then back on for 1 min at intervals. can't hear fan running. Sony HD projection TV model#KDFE55AZ0
  • 4,234 Answers
Generally speaking the lights on the front usually will blink a code or at least light up in a code. Check for that and look in the woner's manual for the reasons for the indication. If you can not hear the fan or feel any air flow, check the fan and clean it if necesary. The fan should turn fairly freely with the power off. Also check the area and clean out any dust that is there. When closing the access door, make sure that it is properly seated or the set won't turn on at all.
Please try the above and report the results. Lets get the simple reasons out of the way first.
Thanks,
Dan
Posted on Jul 21, 2009
Rca projection tv wont stay on but about 1 min then powers off and wont turn back on for about ten minutes then shuts off again after a min or so
Possibility Fan Cooler Issue Check at the back if your hear the fan going if not your fan cooler is burn out .... The Thermistor will shut off the TV automaticly to the unit for Over Heat
Sep 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
When I turn the TV on it comes on for 1 min or so then turns off. I get the green blinking light by standby/power button. Then it comes back on....then off again.....then on. It just comes off and on...
Has the Lamp been replaced yet if not replace it pull backoff watch Fan to Lamp if it stops running while Lamp is trying to turn on Lamp will turn OFF FAN maybe defective. For Parts Call Encompass 1-800-638-3328 Clean out all dusty dirty Fans and around Lamp housing.
Oct 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
The fan in the tv is too loud.
Thiscan happen for two min reasons.
1. Dust
2. Fan's bearing gone bad.
Easiest way is get a compressed air can and clean the fan. (You do not need to take the TV apart)
If it did not work, replace the fan. (Will not cost you more than $20)
Feb 20, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
JVC DLP FAN
If the fan doesn't start then this model will shut down and the power light and lamp light will blink at .5 second intervals. If this is not happening and your unit says on then I would not worry about it. If the tv overheats then it has other shutdown circuits to prevent damage. If your tv does shut down then a technician will need to replace your fan or fan controller board. You can also have them clean the dust out of the interior of the tv to prevent this from happening again. Hope this helps.
Jan 26, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Sony Grand wega lcd projection tv Hd/Tv Help troubleshooting
Did you clean the air filter? Sounds like a thermal problem due to a plugged air filter.
Jan 17, 2008 | Televison & Video
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
