When I turned on my machine it came up. X-Axis home position error. I turned it off unpluggedit. Plugged it in and turned it on it came up the same and just buzzes
2 Suggested Answers
SOURCE: Morbidelli CNC ROUTER (U550) sizing error
I have a low air pressure signal on my Morbidelli U550. Does anyone know of a good service technician in the London Toronto area who does not want to replace the whole air logic system
Posted on Apr 05, 2011
How do i repair X-Axis home position error for pr 600II
If the machine's embroidery arms have been moved under force when the machine's power is on, you may need to have the machine tune up and reset to true center. I would suggest taking it to a authorized repair shop for a good cleaning and service. In most cases for what you paid for the machine, there is included service that can come with the purchase of the machine, or in the least, a discount on mechanical services and repairs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Mar 02, 2015 | Sewing Machines
I had this error message on the screen panel: x-axis position error. How to fix this problem?
have you tried googling (searching) on that sewing machine model and manufacturer and doing a query there. I bet they have advice on this situation.
Jan 24, 2015 | Sewing Machines
I have a Babylock BMP8 that i have an x-axis home position error. How can I fix it without spending hundreds to take it to a technician that is hours away! Please help!
Turn off and unplug machine. Manually move hoop frame front to back and left to right.
Plug in and turn on. Motors driving hoop x and y axis should initialize. If not you must see a tech, If the frame will not move see the tech
Dec 08, 2014 | Sewing Machines
Xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Jan 05, 2010 | Xerox Phaser 8400 Laser Printer
Error 08,045,43:42128
Hi Here are some codes for you
  • Tray 1 status:
08.055.44:
37,008.44:
05,002.42:
assembly.
All Best: Pineworks
Jan 04, 2010 | Xerox Phaser 8400 Laser Printer
Problems with Xerox Phaser 8400 Laser Printer? erro 37,004.40:92384
TRY
  • Tray 1 status:
08.055.44:
37,008.44:
05,002.42:
assembly.
Oct 01, 2009 | Xerox Phaser 8400 Laser Printer
Xerox 8400 error 07.010.43:52882
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
Do the printhead lock arms rotate correctly.
Has ink spilled ink around the printhead that prevents the printhead from moving to its center position? You should be able to manually push the printhead right to left.
Does the X-axis motor drive the printhead to it’s center position (so it can tilt forward)?
1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
Has ink spilled on the head tilt gear on its drive train (near left side of the printhead).
Aug 30, 2009 | Xerox Phaser 8400 Laser Printer
Slow down the feed rate to about 25% and then size it ,and that should work.The problem i believe is in the Z axis ball scew.
Mar 22, 2009 | Tools & Hardware - Others
PHASER 8550D error report 07,010.43:217298
replace the clutch.
drive system.
Sep 24, 2008 | Office Equipment & Supplies
k24674
