Question about Dishwashers
Dishwasher won't start and flashing alternately between F2 and E2
2 Suggested Answers
  • 5058 Answers
SOURCE: My kenmore dishwasher is flashing E2 F2 what do I do.
Since you didn't add the model number for your dishwasher, I can't detail any specific fixes. The F2E2 error usually means that the display panel (user interface panel) isn't communicating with the main control. This could be a sign of a bad panel, a wiring problem (loose wiring harness or the wrong panel being installed) or moisture inside the dishwasher. Unplug the dishwasher then you can check the unit.
A common source of the moisture problem is actually loose hose clamps at the pump. That lets water get into the control wiring. The error will reset after the entire unit dries (2+ weeks). You might find the moisture when you pull the unit out of the cabinet for a built-in model. For the other problems, you open the cover and check the grey wires between the LCD panel and the P12 section on the main control.
If your dishwasher is under warranty or are uncomfortable with electrical wiring, you should contact Sears for service before opening the cover to access the wiring.
I hope this helps.
Posted on Jan 29, 2015
I have agbd307pd whirlpool goldaccubake system it starts but then shuts off with codes e2 F2 e2
Laura Montano, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Laura Montano), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool Kitchen Ranges
I hope this helps.
Jan 28, 2015 | Kenmore Dishwashers
Dishwasher won't fill and e4 is flashing
Possible that the inlet valve or the filter is clogged
Click this link: Inlet valve
Jan 23, 2013 | Dishwashers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Whilpool stove gives errorr message . E1-F2 want come on model# G W395LEpB00 SER# XD3802931
F2 Oven temperature above specifications 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Nov 23, 2009 | Cell Phones
Diplomat dishwasher keeps flashing E2 anyone know what this means
dishwasher starts then goes to prewaash and beeps.When opened it flashes f2.
Dec 27, 2007 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Whirlpool RF196LX Smooth Top Range
4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Oct 21, 2007 | Kitchen Ranges
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
