Removing agitator from frigidare model #FFTW1001PW washer
4 Suggested Answers
SOURCE: Will not extract on spin cycle
After oheming motor control board as stated in the service manual. Tracing the 6 pin lead wires from the control board to the motor plug. I found that one of the pin on motor plug was not making proper connection. I used a screw driver to pry the pin open so it made a better connection. Tried the washer and so far it has been working 7 washes.
Posted on Mar 27, 2008
  • 62 Answers
SOURCE: I have a Frigidare washer/dryer combo (model #
I'm not sure if the heavy load had anything to do with it or not. this unit has a remote pump, which means the pump doesn't run off of the main belt . It actually has a motor of it's own. Basically you would have to remove the front access panel, of course unplug from power, make sure the pump will turn. with the power off you can rotate the cooling fins on the pump motor. if it turns freely then you would have to determine if the pump motor is getting power. If it is getting power then you need to replace the motor.
Posted on Dec 18, 2009
  • 40798 Answers
SOURCE: Frigdaire top loading washer # FFTW1001PW gets stuck in wash cycle. It agitates and drains but stays in wash mode. Is there a way to fix this?
possible problem program board not progressing
call in a technician for a proper diagnosis and quote
Posted on Sep 03, 2016
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
Sep 03, 2016 | Washing Machines
My FFRG1001PW-FFTW1001PW won't spin and drain
Is the pump running. If so it could have something blocking it. The machine won't spin unless the tub is empty.
Sep 27, 2014 | Frigidaire FFRG1001PW-FFTW1001PW White...
Frigidare fws833a51 leaks by the aggitator shaft
Hello - In this particular case I suggest taking the agitator apart for properly cleaning. Once you have done so and tested again, if issue continues contact a professional to move forward accurately. Washer may be experiencing a damage or crack part that has to be further diagnosed.
Oct 31, 2012 | Frigidaire GLTF2940ES Front Load Washer
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
I have a Frigidare washer/dryer combo (model # FLEB8200DS0). My wife washed a heavy load and the washer stopped draining completely. Agitator works fine. Please HELP...
Oct 24, 2009 | Frigidare FEF336EC Stainless Steel...
How do i remove the agitator on frigidare top loader model # fwsb67rgso
Tou should be able to just pull it straight up. If not, remove the top cap and remove the nut, then lift it out.
Oct 16, 2009 | Frigidaire GLWS1339CS Top Load Washer
Fills with water but won't agitate
There is a plastic coupling that connects the motor to the transmission. They very commonly break. If you google frigidare washer parts, you can easily find a parts breakdown. Cheap fix.
Jun 04, 2009 | Washing Machines
Mar 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
