1.9 dti opel pick up wont start
It could be an Immobilizer fault, if the spanner /car light comes on.
If you have a spare key, try it
A Flashing spanner light normally means immobiliser fault hence the non-start. The spanner light left might just be an indication that it has stored the "wrong transponder" code.
Opel will have to clear this but you might need a CIM as well that is the bit that reads the key to allow it to start.
Try the spare key if you have one
On 1.7 DTi models, a defective solenoid in the pump can cause failure of the ECU due to excessive current draw causing components to burn out. but this *should* cause other fault codes to appear.
