After have downloaded Windows 10 I can't get my computer to recognize my machine Help
My Windows 10 computer can no longer find my printer.
try removing printer from control panel - printer and devices (right click start icon bottom left corner - select control or settings from menu - I don't use windows 10 much !)
then right click on start and select system . Note the Windows operating system and if it is 64 bit whether it is windows 10s or windows home edition .
Then go back to hp driver download web site and download the matching driver with your printer model and operating system.
Run driver install program you just downloaded to install driver and it should find your hp printer and set it up in windows.
Feb 21, 2018 | HP Office Equipment & Supplies
I don't have the usb cord that came with the camera, cannot find driver on line and after market cable not recognized, how can I upload to lap top Windows 10?
Contact Fuji customer services for help, advice and possibly the drivers and/or cable that you need. The camera is, however, eleven years old, so they may not have what you require anymore. It takes an xD media card, but you may be able to get a USB card reader that can accommodate that.
Oct 08, 2016 | Fuji FinePix S5200 / S5600 Digital Camera
Running windows 7 home on one PC and windows 10 on another. I don't have the installation disc anymore, and the drivers I downloaded from Dell don't seem to work.
Daisy Mae,
The Pocket DJ is not compatible with Windows 7 or Windows 10. If you plugged it into your computer and it did not recognize the device or show up in "My Computer' then it will not work. You would need a windows 7 and Windows 10 drivers.None are available..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 01, 2016 | Dell Pocket DJ MP3 Player
I dont know how to put music on it
To put music on yourMP3 Player you will do this:
Download Windows Media Player 9 or 10 to your computer.
I would use Media Player 10 as it is the newer player.
After you download Media Player 9 or 10 open it up on your computer, and then hook up your mp3 player, it should be recognized by Media Player and then you can transfer the songs to it.
You need to put the music cd in your computer cd player and download the songs to Media Player using Windows Media Player 9 or 10.
Good Luck, I hope this helps.
Please take time to rate me
Bud
Oct 15, 2012 | RCA Audio Players & Recorders
Usb device not recognized
If you are using Win98, that is the problem, as I think SP2 had an update to use USB, but it was iffy. See if you can download that part from Msoft. for starters. Test it on a WinXP or Vista machine, if it is not recognized, it is probably bad.
Aug 26, 2009 | Microsoft Windows 98 for PC
Help
Ok when you hook it up and it says MTP just push and hold the Play pause key till it says Usb then it should recognize it .....
now mine recognizes it on both usb and mtp i have win xp pro ...  If you do this and it doesnt work
If you are using Windows XP or Vista, make sure that the player is in the Media Transfer Protocol (MTP) mode. This can be done by pressing the M button. This button is located on the top of your mp3 player. Open Windows Media Player 10 or 11 and follow the directions for transferring (synchronizing) music. If you have Windows Media Player 9 on your XP machine, upgrade to Windows Media Player 10 or 11. This can be done by visiting www.windowsmediaplayer.com.
If you are using Windows 98SE, Windows ME, or Windows 2000, you will only be able to transfer music using the USB transfer mode. Open Windows Media Player 9, and follow the directions for transferring (synchronizing) music.
If you have version 9 on Windows 98SE or Windows ME, you will need to visit the Download Center for updated drivers.
Jan 15, 2009 | GPX MW-238B MP3 Player
Computer wont recognize it,need media player 10 or 11 download
Windows Media Player 10 Can Be Downloaded Here
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
And 11 Can Be Downloaded Here
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Im Not Sure Where To Get The Manual But I Own This So Any Questions You Have Shoot.
Jan 05, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Confused!!!!
there might still be hope. If you downloaded firmware version 2.11.01 it will not be recognized by creative organizer; you will need to install plugins to make creative organizer recognize it again. Go to www.creative.com/support --> downloads and follow the links to download the plugins. There are 1 or 2 to download. Do you have windows media player 10? If so then the zen should be recognized in wmp 10 and you can download songs that way. If you have windows media player 11, you will need to roll back to windows media player 10 for it to be recognized. NOTE: if you don't use windows media player to sync songs, then just ignore everything I said about it.
Sep 16, 2007 | Creative Labs Zen Touch MP3 Player
35 people viewed this question
 Grubhead
Grubhead
