Turntable running slow - Audio Players & Recorders
Record player turntable runs too slow. How to troubleshoot?
If this is a belt drive turntable the belt might be in the wrong position or is slack due to wear.
Jun 12, 2017 | Audio Players & Recorders
Why is this turntable running slow?
It depends which type of turntable it is. If a belt one then change the belt, make certain you make a note of how the belt fits before removing it.
Direct drive turntables are more difficult. As it could be any number of faulty parts that cause it.
A build up of grease or dirt in any type of deck can slow the speed down.
A faulty motor on both types of deck will also cause it.
Sep 07, 2015 | Audio Players & Recorders
Why is turntable too slow?
If it's belt drive, the rubber drive belt may be slipping (look inside and see if you can detect slippage).....or if it's gear driven or direct drive.....I'd just let it run for an hour or so and see if it speeds up.
If not, and it's valuable, take it to a repair shop. If it's cheap....scrap it!
Jul 30, 2014 | Crosley CR6007A Turntable
Turntable Speed Problem
the motor has gone or theres a short on the wire going to the 45 switch, or the switch is gone & isn't switching over.
Mar 02, 2013 | Audio Players & Recorders
No turntable for sharp R-1870
The turntable motor will need to be replaced, a common issue with most brands.
Apr 21, 2012 | Sharp R-1870 Convection/Microwave Oven
HMV Radiogram Turntable run slow at the start,
you should check under the table.
if it's a roller drive there, you can use water to clean the roller rubber and the inside edge of the platter.
If it's a belt drive, take it out and measure the length and get a replacement belt of same length
Jul 27, 2010 | Audio Players & Recorders
Technics SL-B205 turntable runs too slow
I have a Techniques SL-23--just bought two brand new belts. One runs too slow and the other too fast.
How do I fix it?
Feb 24, 2010 | Technics Audio Players & Recorders
57 people viewed this question
 Grubhead
Grubhead
