Question about Garden
2410 troy bilt blower 2yrs old used 3 times. Auger wont turn. could it be a frozen up impeller?
  • 68 Answers
SOURCE: blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Posted on Dec 11, 2008
SOURCE: Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Posted on Jan 19, 2009
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
  • 389 Answers
SOURCE: Troy-bilt Model 47279
I really hate to be the "bearer of bad tidings" but Troy Bilt, as a company, in no longer in business, MTD bought out the name and design rights for a lot of their tools but they are not manufacturing or stocking any parts for the older GardenWay/ Troy-Bilt machinees. My best suggestion would be tostart looking for a good used one or one with a blown engine, broken frame or whatever, buy it and canibalize it for spare parts
Posted on Sep 16, 2009
  • 297 Answers
SOURCE: I have a Troy bilt
You need to remove the carburetor float bowl and clean it. The needle and seat also need to be cleaned. The best thing is to totaly remove the carb. and soak it in a commercial/professional strength cleaner.
Your problem is fuel related, but just to make sure, remove the spark plug and spray some carburetor cleaner in the hole, replace the plug and give it a pull. If it fires up then quits..... The fuel system is to blame.
Hope this helps, Matt
Posted on Dec 10, 2010
Troy-bilt snowblower smokes when I try to engage auger. It’s the belt burning, but do I simply just replace the belt or is it something else that’s causing the belt to burn?
How old is it? Model? Can you move the auger single stage or augers 2 stage by hand when in neutral. Could be a ice jamb. or bad bearing. Do this with the unit NOT running. If it's a 2 stage take a 2X4 and insert in the chute
and try to wiggle or move the impeller. Bent impeller/auger? Maybe. check them visually.
Hope this helps.
Dec 26, 2017 | Troy-Bilt Garden
Troy bilt 5524 snow blower with no spark
check kill system... there is a safety switch close to the auger or the cover for it... then suspect a coil but next time, how about mentioning the engine because troy bilt never doesn't make engines
Aug 24, 2014 | Garden
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
I have a Troy Built Storm 5024 the auger is not rotating. I check the shearpins and they are fine, I replace the auger belt still nothing. The impeller is spinning. What am i missing?
I had the same issue. Check the gear box where the drive shaft meets the auger. My problem was the worm gear was missing 3=4 teeth in that assembly
Feb 01, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy bilt Storm 9528 snow blower (about 3 years old). This year I am having trouble with the snow discharging. It doesn't seem to take much snow jam it up. At times the auger barely turns when I...
adjust the auger cable so its tight, it most likely got loose. The adjustment is on the back of the machine theres 2 screws just make the auger cable tighter. this should solve your problem
Dec 02, 2010 | Sport & Outdoor - Others
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
