Question about Keurig Coffee Makers & Espresso Machines
Keurig platinum will come on and heat water but as soon as any button is pushed the screen dies and heating stops. Press a button again and the screen returns. And so on.Can this be reset?
wolfpackicu
  • 26 Answers
SOURCE: Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Posted on Jul 30, 2009
  • 60 Answers
SOURCE: single cup keurig brewer. machine heats up but no
Call Keurig 1800 Cup Brew
Posted on Mar 23, 2010
  • 7 Answers
SOURCE: My Keurig platinum B70 will not pump water through
Please get a hold of the company at the number in the manual, they will send you a new one if they cannot fix it. Magic words, I got it as a gift three months ago, it worked fine until now. Worked on mine. Sending out a new one today. This company works with you until you are happy. and I am getting 4 boxes of coffee! Free!
Posted on Mar 29, 2010
  • 4102 Answers
SOURCE: 2008 Ford Taurus X. Drivers side heated seat
Hi, its bad news im afraid it is the heating element its over heated which they do from time to time so the only way your going to solve this is replacing the element, if the light wasnt lighting up at all then it could have been a fuse or a wire worked loose but as the light is flashing this is showing you a warning message that the unit is no longer operating due to a problem with the heating element.
the only option you have of solving this is to get the whole heating element replaced and the rest checking to ensure it wasnt a short that caused the element to pack up
let me know if you need further assistance ok
im sorry i couldnt give you good news or an easy fix but if you had said the light dont light up at all then i would have said check fuse and or the wiring harness but as your are getting the flashing light then this is telling you that the heater is cutting off due to a fault with the element.
Posted on Oct 04, 2010
  • 40 Answers
SOURCE: platinum B70 keurig coffee maker water heats up
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Posted on Oct 07, 2010
Why doesn't keurig coffee machinte stop working?
heating element bad? is there any warmth/gurgling? at all?
Aug 17, 2014 | Keurig Platinum B70 Coffee Maker
Keurig not taking in water
Pump has died. Factory replacement only.
Dec 28, 2012 | Keurig Platinum B70 Coffee Maker
WATER WON'T STOP RUNNING OUT AND WILL NOT HEAT
Seals failed and need replacing. See manual.
Aug 21, 2012 | Keurig Platinum B70 Coffee Maker
Will not heat water
Try pressing all 3 size buttons down then press menu, it should reset, unplug fro 10 seconds and retry.
Jan 07, 2011 | Keurig Platinum B70 Coffee Maker
Bought this last night...we spent over 1/2 an hour trying to get it to work properly...finally achieved that...now this morning... 1) I can't get the water to heat up, 2) it keeps turning off, 3) as...
Clearly, your issues are related to issues that can only be corrected at the factory.
Keurig Customer Service: http://www.keurig.com/customer-service
Dec 18, 2010 | Keurig Platinum B70 Coffee Maker
Machine shuts off and says NOT READY. It will not work again until it is unplugged for a minute. Plug it back in, water heats and READY. It is not set to shut off. It shuts off soon after using for no...
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
dad
asd
Dec 17, 2010 | Keurig Platinum B70 Coffee Maker
Keurig B66 coffee maker randomly stays on and brews.
I have called Keurig and gotten replacements for units... however... all keurigs will heat water... then stop... after a while, the water will get cool, and the unit will cycle on.
when you say shuts itself off, the whole unit does Dark?
If the whole unit goes dark, then you may have a bad overtemp sensor... most if not all appliances will have this featurew to shutdown everything if the sensors detect a higher then normal temperature.
If that's happening... call Keurig and tell them this,,, they should honor the warranty and ask you to send them you K-cup holder as proof of ownership... then you will get a replacement.
you now have a unit for parts or to sell on ebay for parts...
I can allways use the parts... :)
May 17, 2010 | Keurig Platinum B70 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
