It was working but accidentally knocked off the cover and now it wont turn on. Does it need replacement or what can I do to start it again ?
2 Suggested Answers
SOURCE: 2000 dodge durango wont cranks but wont start...
had same problems with cranking and wouldnt start , i had no spark not sure if you do but if not after performing tune up and still had no luck , i changed my camshaft position sensor under distributor and rotor , and she started right up . good luck
Posted on Jun 14, 2009
My iomega external hard drive just beeps when ever i turn it on. How can I fix this?
ummm, i fixed my problem i had with a iomega 500gb external hard drive, it was beeping at me also, so what i did was i knocked it on its side, switched it off, by its own panel, then switched it back on, it came back into life and was recognised again!!
so try it with yours!
I think what what happens is, when you accidentally drop it, or knock it from time time(accidentally), the needle inside the hard drive goes out of place, and the hard drive will beep, or something to that effect. knocking the case itself again, might fix the problem, or maybe not, thats if the hard drive itself is more severely/inherentally faulty.
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
It wont crank over, Have changed the crank censor, knock censor and body modual censor still wont work . If I diconnent the battery and main computer for a few min. it will start but once it is turned off...
Without test main componets on the vehicle we would only be guessing . Doing electrical checks , hooking up a professional scan tool an viewing engine data etc. your best bet ,take it to a qualified repair shop . Spend the money for an hour diagnostic time .That is unless you like guessing an just replacing parts
047 Engine Hard to Start or No Start Scan Data for Ignition
048 Engine Hard to Start or No Start Scan Data for Starting Problems
Sep 06, 2017 | 2005 Pontiac Montana
Oil pump went out replaced it. now the truck wont turn over.
Usually a knocking noise means that a rod bearing is worn out. Since your oil pump was replaced, you may have spun a bearing. I would suggest that your engine needs to be replaced.
May 20, 2009 | 2000 Chevrolet S-10
Mar 15, 2009 | 2000 Dodge Durango
99 kia sportage starter
Theres a solenoid on the starter to engage the starter onto the flywheel. The solenoid could be going out.
-Captain Jake
Feb 13, 2009 | 1999 Kia Sportage
PS2 doesn't work
Dear Customer,
Due to the knocking of ps2 by ur son,it might have affected the reading lense of the ps2.so i request u to open the console.you would see another cover covering the lense.open tat too.with the help of tissue just try to wipe out the lense n jus turn on the ps2 without closing anythin to jus check whether everythin is workin..if the dvd works,then arrange back or put back everythin back to it's position..hope this would work...else try calling a service engineer.
please rate this solution if it meets ur needs else choose fixya.Thank you...
Dec 17, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 wont turn on
Droped it , now your screwed
Nov 15, 2008 | Sony PlayStation 2 (PS2) Console
Disk cover open, accidentally. Turn on power again
Haha, yes finally what a pOS!, But I got it!!
So I got to thinking well the sensor or something be messed up a bit. I found that the cover a very slight amount of play.
So hell , I put a C clamp on it. I started to record. Sweet, it worked!!! The cover was stuck so the sensor wasn't tripping.
Well that worked, but I didn;t want a c clamp on my camera all the time, so I had some Automotive Amazing Goop,
I lined the cover edges with the sealent and let it dry. Now when I close it , it stays closed and records without a problem.
The only thing is its tuff to open, I use a skrew driver, or small nail.
But it was unusable before, and at least I can use it.
Good luck.
Sep 25, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Accidentally knocked the disk tray out of my friends xbox
Out of your what?  360?  How did you accidentally knock out the disk tray!?
Please explain with more detail!
Dec 06, 2007 | Microsoft Xbox 360 Console
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
