Question about Kenmore Dryers
Kenmore 90 series dryer wont start, just hums
Sounds like the motor has seized
    Top Expert:
  • Kenmore Master
  • 47,680 Answers
Get in a technician to check/ replace the start/run capacitor for the motor
if that proves not to be the fault he is there to do a proper diagnosis and quote
Posted on Dec 19, 2016
DRYER MAKES HUMMING NOISE BUT WONT START
Sounds like the capacitor on the motor is faulty
Mar 21, 2014 | Kenmore Series 70 80 90 PN281798 Dryer...
How do I know if motor is bad on a kenmore 90 series dryer
you have reassembled it incorrectly and now the motor cannot drive the drum
Nov 25, 2017 | Kenmore 62602 Electric Dryer
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
With the Kenmore series 80 Dryer plugged in, Pressing the start button causes the motor to hum as if the belt, pully or motor is frozen. The drum doesn't turn during the humming and is difficult to turn...
You'll need to remove the back panel and determine the cause. Look for:
Seized drum support rollers (3)
Seized drive and/or idler pulleys
Burned out or seized motor
Possible bad motor start capacitor (if equipped)
Drum alignment
Mar 29, 2009 | Dryers
Kenmore 90 series won't start timer ticks
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore series 90 dryer
I hae to say it, but it sounds like the motor has already gone out. That loud humming noise is usually the start windings going out. There is no other way easily to tell if the motor is out, but taking the belt off and saying it doesnt look broke what work in this situation. I would imagine that you have a DOTT (Dryer Of Tommorrow, Today) dryer, because you said it had the front panel. The motor part number is 279787 if this the case. Good Luck, and let me know if you find out any new information or need further help.
Feb 12, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
