Question about Health & Beauty
Salter scales model 2006 error
How do I reset it?
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
Posted on Aug 18, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
Posted on Oct 20, 2009
  • 10865 Answers
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Posted on Mar 26, 2010
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h the g-oz key to set the time.
And your done.
Posted on May 23, 2010
Calibrate Salter model 9140 bathroom scales
Remove the battery and count to 10 and then replace it.
i found this
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
and also this
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery until you first complete the steps listed above.
Not sure if this is the correct manual, but may be close. Page 3 and 4.
Salter Housewares Body Fat Computer Instruction Manual Page 3
Nov 27, 2017 | Salter Health & Beauty
How do i get battery compartment open on Salter kitchen scale model 2006
I went to the Salter website and I could not find that model number.
Salter Disc Electronic Digital Kitchen Scales White
However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
Nov 22, 2017 | Salter Health & Beauty
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
How do i contact salter scale customer service i have a waranty issue with a scale
you can contact our customer service by this email address
Aug 04, 2009 | Salter Stainless Steel Electronic Bathroom...
Health & Beauty Logo
59 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
