Question about Hotpoint Washing Machines
Does my washer need its own circuit it is a120v 60hz 10amp hotpoint, it's brand new
It starts to fill then stops and drains, I tried putting it on drain and spin and only the spin ligh t comes on the machine doses nothing
    New Friend:
  • 14 Answers
Yes, it should have a 20 amp circuit. But I don't know if that will correct your problem..
Posted on Dec 19, 2016
After fitting a new time to a hotpoint CDT00
Sometimes even one connection can make the circuit non functionable and so it can be due to a wrong connection. I request that you check once again and logically check the lines to go in order to start the cycle, INLET, cut off from the water level sensor, Start motor, stop and drain, spin and rinse, fill water and then for final dry and drain pump.
Check for all leads to be correct, check if the stepper motor works in circuit to move forward after the main power is switched.
Check this link for tips: washing machine
Jul 02, 2012 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
No drum movement during wash/spin cycle, although it fills/drains
brushes need replacing in motor. Usually cheap enough to buy and do yourself.
Jun 02, 2009 | Hotpoint WMA46 Front Load Washer
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
NOT FILLING PROPERLY
have you got the drain pipe going up to about worktop level of machine?
if the drain just goes downwards then the water just runs out as fast as it comes in. get a sililiar situation if you put drain pipe too far down a standpipe - then a syspon forms and water drains out
Jun 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint wd420
Check if the hose from the tub to the drain area has come off; refit carefully. This could happen if the tub is unbalanced, happens sometimes.
Pl rate if helped..................
Dec 28, 2007 | Hotpoint Aquarius WD640 Front Load...
Circuit board
It sound like a malfunction circuit board issue that shouldd be replaced.
Jun 20, 2006 | Hotpoint WD52 Front Load Washer / Dryer
Washing Machines Logo
27 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
