Question about Dryers
What is the designation (type) of 3 prong female receptacle on the battery box of the Shoprider Echo 3?
  • 1122 Answers
SOURCE: Swapping dryers
just remember a 3 prong cord the middle wire goes to the middle on the terminal block,the other 2 does not matter there both 120 volt,same if you have a 4 prong,the white wire goes on the middle on the terminal block,the red and black go on each side and the extra green gets mounted to the cabinet,,let me know how you do-mike
Posted on Mar 23, 2009
breddi2
  • 126 Answers
SOURCE: Elkectric dryer won't start
to put it kindly depending on way you connected wires unit could be damaged,replace pigtail with three wire and outlet to original.outlet wires should be black,red and white. turn breaker off attach white to middle and red,black to sides,"either side is fine".Attach dryer pigtail in same manner with white on white and if plug in and turn breaker on.If there is no operation at this point dryer possibly damaged from previous wiring.Just remember be safe when working with electrical and ask before trying to change things that aren't the same.
Posted on Apr 20, 2009
jsrock516
  • 5911 Answers
SOURCE: We have a kenmore 70 series electric dryer, and we
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Posted on Aug 02, 2009
hondo73162
  • 132 Answers
SOURCE: I was given a used kenmore series 80 electric
usually 30 amp and there are several different configuations, they are available at hardware stores, and very east to switch over at the back of dryer. draw up what it looks like and take to hardware store and they should be able to set you up
Posted on Oct 17, 2009
  • 2341 Answers
SOURCE: I need to change from a 3 prong to a 4 prong
the green wire is just a ground,as long as it's touching any metal on the frame of the dryer you're ok,put the wires the same way white in the middle,red on one side black on the other,on the back inside wall where the block is that your wires are connecting to there's a green ground wire in there that you can remove the screw that holds it on and also connect the new ground wire with it or like i said you can remove any screw that's close to the block and ground the wire there as long as it's grounded to the frame of the dryer
Posted on Apr 18, 2010
Shoprider Echo 3 wheel mobility scooter-will not move. When key is turned on, there is just a continuous beeping. Battery is completely charged
Have the battery load tested because the symptoms are for a dead low battery. Just because it shows charged doesn't mean it is any good.
Jun 28, 2017 | Shoprider Health & Beauty
Shoprider Echo 3 throttle spring
hi ,so me picture of this string , i have loads of strings , make sure i send you the right one :)
Regards
Rob
www.gewizrepairs.co.uk
Aug 28, 2013 | Echo 3 TE SL7 3 New Electric Scooter by...
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
Where do i get new battery?
tanya anywhere you want to !!!! No seriously if there is a battery type warehouse or dealer in your area you can find them there or an Interstate battery dealer. Even could try an auto parts store but make sure you get sealed batteries I even have found them at Academy Spoting goods in the hunting section. You need 2 12-12ah batteries for your scooter Hope this helps
Nov 19, 2010 | Shoprider Echo 3 Wheel Scooter
I need a new battery and charger and every where I have called either pushes me off to some plaace else that doesn't answer or a place never calls me back. Where can I get these items?
The type of batteries required by your scooter are 12volt 10 Amps, you will need two of them. They can most likely be purchased at any industrial battery store like Interstate Battery or Batteries Plus. For the charger, you will most likely need to contact Shoprider direct OR a licensed distributor of Shoprider products for that to make sure that the charger will fit into your scooter. Shoprider Mobility is 1-800-743-0772. Another company that sells Shoprider products and may be able to assist you is Marc's Mobility at 800-677-6293.
I hope this information is helpful- good luck!
Sep 20, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Installing cooper 30A 250V female receptacle.
Correct, assuming red and black are connected to the breakers in the breaker panel, and white is connected to the neutral/ground buss bar in the breaker panel.
Dec 17, 2009 | Cooper Wiring Devices ACE6001V-K "ACE"...
Dryer 4 tp 3 pring cord install
Hello wgirdler,
While it is preferred to upgrade the receptacle to a 4-prong type (which includes Neutral & Ground) Code requirements grandfather in 3-prong receptacles in older homes. So if your preference is to remove and replace the power cord on your dryer, make sure you get one that is designed for a dryer application and is 10/3 type. ( 10 Gauge wire with 3 conductors)...
Unplug the original 4 prong plug from the receptacle and pull the dryer away from the wall to gain access to the back of it.
Next, loosen the cord clamp that allows the cord to pass thru the back panel and into the druer compartment.
Open the access cover to where the end of that cord is terminated on a terminal block of the dryer.
Note which color is attached to which terminal ( red to red,black to black, white to white and green to green)...
3 Prong cables do not use a ground wire ( green) in the cord so you would wire the red to red, black to black and white to white ( The red and black are the power conductors and the white ..which is normally terminated between them.. is in the middle. You can get a seperate insulated conductor wire and route it from the ground stud of the dryer to the receptacle metal casing but do this with power disabled at the circuit breaker box...
Hope this helps.
Regards,
Rick
Nov 29, 2008 | Whirlpool LER5636P Electric Dryer
Need new battery for echo 3 scooter
I have never heard of the echo, but there are several sites on the internet that sell scooter batteries. You can also buy your batteries direct from shoprider.com at this link
The batteries are about $70 each, and there are two of them in the pack.
Nov 22, 2008 | Echo 3 TE SL7 3 New Electric Scooter by...
Dryers Logo
Top Dryers Experts
