Question about Ford 8N Tractor
Ford 8n tractor.when i put a load on the pto , it pops off
When i put a load on the pto , it pops off after about 10 seconds or so. you can hold the lever in place, and it will stay engaged, but you can feel that it wants to pop out, also, the pto shaft moves in and out about an inch, if you push it in and out. help!!
  • Anonymous Mar 19, 2014
    PTO won't quit turning when disengaged on Ford 5000 Diesel
  • 3 Answers
Your PTO shift houseing is going out. I just repairs the same problem. You have to seperate the cases just in front of your lever to engage your PTO. The shirt fork is bent. Go to http://www.just8ns.com/index2.htm for parts and they also have a number on there sit for technical advise.
Posted on Aug 26, 2009
  • 491 Answers
You should repair that PTO system before it gets worse.
Get a repair manual and fix it.
I can't explain the repair here.
Keep in mind.......everything on your tractor is easy to fix.
Posted on Aug 25, 2009
Cannot turn distributor by hand on a 1950 ford 8n
It is frozen, hit it with a soft faced hammer.
Sep 22, 2016 | Ford 8N Tractor
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Does the pto have anything to do with the lift on a tractor?
Sometime around 1950 Ford tractors started using "live PTO". Prior to that the power lift for equipment required that the PTO be on and running (turned on by a lever on left side of chassis below the driver's seat). So 'yes' the older tractors (many in use today) require the PTO to be running in order for the lift arms to lift equipment. I find this very annoying when trying to run a mower, especially when the hydraulics don't hold very well.
Jun 27, 2014 | Ford 8N Tractor
Why will the PTO pop out of gear especially when traveling down hill?
A manual transmission jumping out of gear is a sign of excessive gear lash. Your transmission bearings need to be replaced before the gears are damaged. This is a BIG job.
Jun 05, 2014 | Ford 8N Tractor
PTO will on turn while under load
most pto operations have a 2 position clutch. Full down to select gears and 1/2 down to release pto when travelling. Check that clutch pedal operation is correct It may need adjusting
Apr 03, 2013 | Ford Tractor Grill 2600 3600 4600 5600...
Pto problems
The internal parts are damaged.
Jun 01, 2012 | Ford 8N Tractor
Is there a way to operiate the hydro to raise and lower with out the PTO spinning
If your tractor does not have "live pto", then neither the pto shaft, nor lift arms when the clutch is depressed.
I don't think any 2n's, 9n's, or 8n's came equipped with a live pto.
Hope this helped.
Jan 23, 2011 | Ford 8N Tractor
How to unlock a starter on an 8n ford tractor
Put tractor in highest gear and rock back and forth by hand using rear tires.
Feb 25, 2010 | Ford 8N Tractor
8N PTO will not disengage
Pulls the bolts from the lever cover. You should be able to remove and inspect to see if the fork is busted or shaft it bent. go here for tech help and or parts/ manuals...http://www.just8ns.com/index2.htm
Jul 09, 2009 | Ford 8N Tractor
My pto wont go in gear; 8n tracter.
Try it while just coming to a stop.or just starting to move forward.
Depress the clutch and push it back towards engagement position....because it's tied to wheel speed the moving parts might allow it to drop in.
Apr 15, 2009 | Ford 8N Tractor
Ford 8N Tractor Logo
1,167 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
