Question about Crosley CR40-RE Mini Portable Record Player Turntable Spare Needle
Need the stylus for Thomas Pacconi TPC 7470. Will np1 work?
I have a Thomas Pacconi Model TPC-MSE-807 turntable. The Power/Volume Control has gone on it.
Look on the data plate to see if there is a voltage and current draw value on it. The switch should be rated at 120 Vac @ 10 A.
Feb 02, 2017 | Dual Audio Players & Recorders
I need a needle for thomas pacconi phonograph model tpc-hd-12 can you help?
What you do is look at the cartridge it fits in, then note down the make and model number and enter that into Google. The stylus should then show up.
May 30, 2016 | Audio Players & Recorders
I have Thomas Pacconi 3-speed phonograph model TPC-7475 and wanted to attach external bookshelf speakers. Is there any way to hook speakers up to the line out jacks?
You need to buy the Jack's male plugs, Wal-Mart has them if memory serves, and splice your speaker wires onto them, preferably with a soldering gun and heat shrink insulation.
Jan 12, 2015 | Seth Thomas Pacconi Turntable
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
Speed problem on Thomas Pacconi Turntable
probably need the rollers rebuilt
check out needledoctor.com
Dec 02, 2008 | Technics SL-1200MK2 Turntable
Crosley CR40-RE Mini Portable Record Player Turntable Spare Needle Logo
41 people viewed this question
Top Crosley Kitchen Ranges Experts
Vitaliy Gins
Vitaliy Gins
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
