If ok is an amplifier realistic mpa-95 esque I don't have the schematic of the amplifier for that reason it was my question as assembling them
5 Suggested Answers
SOURCE: Looking for manual Realistic MPA-40 35W
I have a realistic mpa-40 35 -watt pa amplifier owner's manual
cat, no, 32-2032A
You can conyact me @ ltlerock@aol.com
Posted on Jan 26, 2010
petraman7
  • 1175 Answers
SOURCE: Need manual for Radio Shack MPA 95 PA amplifier
http://support.radioshack.com/support_audio/2842.htm
Posted on Apr 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: Need specs and all info
http://support.radioshack.com/support_audio/26947.htm
http://support.radioshack.com/support_audio/doc62/62610.pdf
Posted on Apr 29, 2011
Terry Corrow
  • 10875 Answers
SOURCE: How do I hook up my realistic mpa 25 20watt pa amplifier
hook up speaker common wire to com,then hook up the speaker wire to whatever ohm the pa speaker is,regular ones are 8 ohm,stay away from 70 v,plug in a record player or aux in the rca jacks you can use 12 volts or 120 volts
Posted on Jul 21, 2015
Jul 21, 2015 | Audio Players & Recorders
Looking for service manual for realistic MPA 80 MODEL 32-2026
If it's on both channels the hum could well be produced by the main power supply capacitors. The big ones. Replace all!
Dec 11, 2013 | Audio Players & Recorders
I'm replacing a JAMO amp.
The 201 is 100w in to 4ohms and the 101 is 50w into 4 ohms other then that there the same
Mar 24, 2010 | Jamo MPA201 2-Channel Amplifier
cat, no, 32-2032A
Jan 03, 2010 | Audio Players & Recorders
Realistic MPA-35 amp by Radio Shack
It's not that this amp isn't like "newer amps" with + and - terminals, it's that this amp is made for public-address system use. This kind of amp is used in a store, for instance, to pump background music through speakers all over the place. The terminals you connect to are determined by total impedance of the speaker configuration used.
Most single speakers, or the two- or three-way cabinets for home stereo systems, are 8 ohms. If you're connecting a single speaker you use the "common" and "8 ohm" terminals on the rear panel. With multiple speakers, you need to figure out the total impedance and use the appropriate terminal. In series, impedances add. Two 8 ohm speakers in series would total 16 ohms, so you use the common and 16 ohm terminals. In parallel, the total impedance drops. Two 8 ohm speakers in parallel total only 4 ohms. You need to figure the total impedance of the speaker configuration and connect accordingly. Too great of a mismatch will damage the amp or speakers or both.
You might be able to find the manual for this amp on Radio Shack's website. Here's a link to the manual for the model MPA-40 which should have similar output terminals. The basic information about figuring out total impedance and general use of PA amps applies to your amp as well.
Jun 16, 2009 | Audio Players & Recorders
61 people viewed this question
 Grubhead
Grubhead
