Question about Garden
Bought a rechargeable starter for my leaf blower cause it's hard to start but the charge light dose not show charging and it did not do anything out of the package
SOURCE: not charging
thank you
Posted on Nov 29, 2007
SOURCE: Trimmer Not Charging - No CHARGE Light too.
I have the same problem using Remington MB 200
Posted on Apr 11, 2008
  • 14 Answers
SOURCE: New charged battery in 2004 Mountaineer, but it won't start.
check the fuse
Posted on Oct 31, 2008
  • 63 Answers
SOURCE: My leaf blower will not start, It keeps flooding
To start: turn the choke off, hold the throttle wide open and crank. You have a carb problem but this should get you going. John
Please rate if this helps-
Posted on Mar 20, 2009
SOURCE: cannot recharge battery on my explorist 400 gps
I had the same problem with mine, the AC adapter fails really quickly. Try to go to Radio Shack and get the 3-12v switch able AC adapter that is 1 amp, and select the 4.5 volt setting. This setting is a whole .5 volts less than the one that comes with GPS, but its the Amps that matters. Make sure you get the correct plug with the adapter, I got the "B" plug and follow the directions that came with the adapter to match the right polarity, or you will fry your GPS. Also, the computer just supplies enough power to run the GPS, but not to charge it as long as you have the USB 2.0 ports.
Posted on Apr 24, 2009
Hi, I have a new ryobi touch start weedeater. I have used it twice. I charged it overnight for first use. It worked fine. After 2nd use ran out of charge so I re charged it . It doesn't seem
If it doesn't seem to be recharging or taking a full charge, check the charging jack to make sure no foreign object (leaf debris, etc) got into it. If it is clean, then you probably have a warranty issue with the battery or charging system.
Note: do not leave the string trimmer out in the sun or outdoors in cold weather while it is charging. The charging process only works properly at room temperature. In particular, lithium batteries are very finicky about charging conditions. Charging overheated lithium batteries can cause a fire, so they have a safety circuit to prevent charging outside the proper temperature range.
Nov 30, 2014 | Ryobi Garden
Air Hog Pocket Copter won't charge
If this was the original charger for the air hog copter and it just started to fail in recharging , there must be a faulty part inside the charger that is causing the problem, staying red light during charging period and never turns to green or other color to show that it was charged is one problem but when it also shuts off after 30 seconds without charging definitely shows a faulty part or parts inside the charger. To check this out you can try another good charger which you can borrow from a friend to see if it would charge your copter or you can take it to the store where you bought the copter , they may be able to confirm the fault on your charger, if it can be fixed or needs a replacement.
Dec 27, 2013 | Spin Master 1001130 Air Hogs R/C Pocket...
Blower part stopped working. What could the problem be?
see the steps and fix it. GOD BLESS YOU
  • 1
    Find the cause of the problem. This may be obvious: if the starter cord is broken, then obviously that's your problem. But if you simply have a blower that won't start and nothing apparent to cause the problem, it's time for a bit of investigative work.
  • 2
    Examine the starter mechanism. Is the spring in place? Is the rope wound tightly? If anything is coming apart in there, then your starter won't work properly, and you won't be able to start the machine.
  • 3
    Check the spark plug. If it is old or appears blackened or corroded, it may be keeping the blower from starting.
  • 4
    Check the fuel tank and fuel line. If the cap on the fuel tank is missing, cracked or failing to seal properly, or if you have a leak in the fuel tank, the lack of pressure in the fuel system will cause problems. Check the fuel line as well for any cracks, leaks or stoppage.
Fix the Problem
  • 5
    Repair the starter assembly by removing it from the body of the blower. You can take it to a repair shop to have it rebuilt for a small charge (usually less since you've already removed it), or you can repair it yourself by purchasing a new spring and starter rope, installing the spring and rewinding the rope. Then screw the assembly back into place onto the blower.
  • 6
    Replace the spark plug by unscrewing the old one, brushing away any debris and screwing in a new spark plug.
  • 7
    Replace the tank or line. This is the only way to repair leaks in the tank or line. Be sure you order the correct part (not just any tank will fit any blower) and the right size of fuel line (usually one of the smallest available). If you're not sure, call a repair shop and have the model and serial number of your machine handy. With this information, they can help you find the right parts.
Nov 13, 2013 | Husqvarna Handheld Leaf Blower 125b
Duralast jump starter says charged but it's not?
You already have a bigger problem. The internal battery won't hold a charge. Time to replace it.
Jul 05, 2013 | Air Tools & Compressors
Batt dead jump start does not seem to charge
Sounds like a dead or shorted cell battery. Charging system is probably working but is showing overcharge since it is trying to charge a brick. Replace the battery and all should be well.
Jun 02, 2010 | Toro Lawn Mower With Toro Power Tools
Stihl backpack blower starter rope is pulling harder and harder. When it dose pull it starts right up.
See if your rope pulley is opening up and allowing rope to double over on itself.When this happens the rope will wedge in pulley causing it to pull hard.
Nov 15, 2009 | Garden
Lights up when turned on,but repeated clicking when you try to start it
dose it start when you get a boost off, and if it dose you need to check your battery connectors they may need replacing, and if thats not the problem make sure that your alternator is charging your battery and if non of these are the problem you need a starter.
Dec 30, 2008 | 2001 Honda Civic
Dead battery or starter?
Take the battery out and have it charged up. reinstall it and you should be allright. Your car has discharged it completely, and it will need a recharge to start. The gauge is only measuring voltage, and not the status of charge.
Aug 06, 2008 | 1994 Oldsmobile Cutlass Supreme
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
