Question about Furniture
My 1970s table stopped working. I understand it was the first model Dynamo introduced a digital scoreboard. I have changed the fuses. The fan works when plugged in directly.
SOURCE: Changing fuse on Nutone Allure Ws2
Hi Mertl, I sure hope you found the solution since, but I am posting the answer for other people like me (and you) who need to find it !
The service manual says:
To replace the fuse:
1. Disconnect power at service entrance.
2. Remove filters, bottom panel, light wire harness, and air chute.
The fuse is actually right behind the fan controls, so to access it you need to disassemble everything that's in the way.
BTW, for anyone wondering if it's the fuse that's faulty, here's a clue:
If the fuse has opened (blown), the green fan-level indicators
will operate properly when the fan buttons/switches are pressed
- but the fan and lights will not turn on.
The fuse is a 5 x 20 mm, 10 Amp, Fast-Acting, 125V (min.).
Good luck all !
Posted on Oct 05, 2008
  • 9098 Answers
SOURCE: display panel works but no heat, no fan, turn table doesn't turn
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Jan 12, 2009
SOURCE: Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Posted on Apr 26, 2010
  • 2317 Answers
SOURCE: 1988 VW Cabriolet- All turn signals have stopped working.
The relay is in the fusebox, above the fuses. Looking at the relays, it's in the first row, above the fuses, should be the one on the far right. Problem should be that relay.
Posted on May 06, 2010
Testimonial: "Led me right to the problem only minutes after posting the questions. Now to find the part! Thanks"
  • 21 Answers
SOURCE: Fan blows fuse
i am sure the fan is burned up is there any writing on the fan saying how many vdc or vac
Posted on May 10, 2010
How do you change the time from military to standard on a digital scoreboard clock?
can not say as do not know what make or type watch you have .
Oct 06, 2017 | The Watches
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Sep 02, 2014 | Kenmore Microwave Ovens
Which Air Hockey table should I buy?
If you want an approved for USAA tournaments then you can check out any of the 8 foot long Dynamo Air Hockey table, just stay away from the "Hot Flash" series.
In the "Hot Flash" Air Hockey tables the painted rails make the puck fly off a lot, and fluorescent table-top makes it hard to see the puck.
A new Dynamo table price varies from $1500 to 2500$ so you should take it into consideration.
Jul 25, 2012 | Sport & Outdoor - Others
your motors thermal fuse has burned out you have to buy a new fan sorry but they are made so cheaply unlike the ones that i have which were made in the 70's and are still working but those fans have a thermal fuse and if you let the on for too long they will burn out
Dec 31, 2011 | Holmes Products HAOF90-UC Table Fan
I have a Harvard Model G03614F Air hockey table. Everything on the table is working except for the scoreboard. All of the wire and clips and molex plugs are where they should be except for 1 3 prong...
I would say the best bet it to call the Escalade Sports Customer Service number and see if they can help you get replacement parts. I am going to put a call in myself to get a new junction box (I have no power to the fans, but the scoreboard works) and some new strikers and a puck. I got my table from a friend who had been using it and then when I set it up it would not turn on...guess that explains why it was being stored in his garage when I picked it up!
The Escalade Sports Customer Service number is:
Jan 01, 2011 | Video Game Consoles & Games
Electrics not working
First check the dynamo outlet for current for that take one electric holder with D.C bulb(12 volt) in it and check whether the dynamo is generating the current or not.If it is O.K then check every cable subsequently using electric holder and
bulb(12 volt).
and if the dynamo is not working them you need to change the coils of the dynamo.
Jul 01, 2009 | 1999 Sym Husky 125
Cant find parts for Harvard Air hockey table I need a scoreboard
amazon is your solution. click here Amazon com Harvard Air hockey and chose your part. If you can't find it, feel free to contact any vendor, and they will provide to you I hope.
enjoy and best of luck
Jan 02, 2009 | Harvard Ice War 7' Hockey Game Table
Samsung BCE1197 oven stopped working after making a noise which I think may have been the fan, maybe something caught in the fans blade or a mechanical problem, anyway I changed the fuse in the plug, still...
Since this is a UK Model, I'd suggest you contact Samsung's to find service info here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 16, 2008 | Samsung Microwave Ovens
Furniture Logo
98 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
