Question about Kenmore Dishwashers
Kenmore elite dishwasher water left at end of cycle
futureloginn
  • 734 Answers
SOURCE: KENMORE DISHWASHER WATER DOESN'T SPRAY.
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve
The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely
replace it. It's usually located behind the lower access panel on the left or right side. It's the device
with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two
wires attached to it.
Float switch
The float switch is a small electrical switch that's located right below the dishwasher "floor."
Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills
the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised
position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Dec 12, 2008
SOURCE: kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Posted on Jan 02, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
plnolte
  • 62 Answers
SOURCE: Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
Posted on May 12, 2009
heatman101
  • 43501 Answers
SOURCE: My dishwasher does not drain completely. There is
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jun 04, 2010
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
Should the inside of the elite dishwasher still be wet at the end of the cycle?
Martha,
If you are talking about having a small amount of water down in the bottom of your dishwasher, that is normal. There is a sump down there that needs to have water in it. If you are talking about having water on the walls, that is probably just condensation from the cycle when you run the heater. Try cracking the door after the cycle is done to let the excess steam out of the dishwasher and that may eliminate the water on the walls. Hope this helps!
Apr 03, 2015 | Kenmore Dishwashers
Kenmore Elite Dishwasher doesn't pump all the water out at the end of cycle
How much water? Does some drain out. If so its usually a dirty filter. Some Dishwashers have several filters underneath the bottom sprayer. Here is a link that may help http://www.managemylife.com/mmh/articles/authored/video-when-to-clean-a-removable-dishwasher-filter Also this link put in your model number and view how to clean your specific dishwasher. Hope this helps.
Sep 14, 2012 | Dishwashers
Kenmore Elite: - Stale smell from dishwasher, won't go away, lingers on dishes, glasses. I tried a vinegar remedy suggested by a diy site - it helps for a cycle or two, but the smell comes right back. ...
try useing your heat to dry at the end of wash,or mabey take and blow your unit out with a compressor and attatchment especially the drain outlet. also run a cycle with just a little lime away then flush with a second rinse.
Oct 13, 2010 | Kenmore Dishwashers
My Kenmore elite dishwasher 665.13793K600 has 2 problems: 1. won't drain water 2. won't even start working today Please help!
I have a Kenmore model # 665.13793K600 and it has been having a small puddle of water remaining in the bottom at the end of each cycle. I've taken it apart and cleaned it. I'm thinking I may have the drain hose incorrectly positioned or it could even be something unrelated. I can only think of the drain because I replaced the kitchen faucets a coupe of months ago and it could be since then that this has been happening.
Sep 09, 2010 | Kenmore 24 in. 15079 Built-in Dishwasher
The water pipes rattle violently in the beginning of the cycle.
My Kenmore 16464 dishwasher caused a buzz in the water pipes at the start of the cycle that I thought was just water hammer. It turned out to be a bad water inlet valve on the dishwasher that has water hoses (inlet and outlet) attached plus has an electrical connector. It is located near the front left underneath the tub. I pulled the dishwaher out and replaced it and all is quiet again. - Jim
Nov 13, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
Dshwasher has water on the bottom after cycle
your drain line is clogged or your pump is bad check both. the drain push a coat hanger down it and see if you can pull anything out.
Dec 08, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
29 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
