Question about Kenmore Washing Machines
Kenmore ultra fabric care II 80 series. Washer won't start on 10. But it will start on 4, every position past that and run thru the rest of the cycles fine
  • Kenmore Master
  • 5,323 Answers
I WOULD SUSPECT THE TIMER CONTACT POINTS AT 10 ARE BURNT OR SEIZED YOU CAN TAKE APART AND CLEAN THE CONTACT POINTS IF U KNOW WHAT UR DOING.
  • 277 Answers
SOURCE: "dog ears"
hi go step by step and you'll do great http://www.american-appliance.com/service_pages/wp_dd_wash/dddogreplacement.htm minor changes are possible good luck
Posted on Mar 29, 2006
abhishek33
  • 1239 Answers
SOURCE: kenmore ultra fabric care heavy duty washer 80 series
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
Posted on Sep 13, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Posted on Mar 13, 2009
SOURCE: kenmore ultra fabric care heavy duty 80 series wont spin
I contacted partsdepotonline.com. They were very helpful. The problem is a broken coupler. Part #100017 from Parts Depot. Part #275753A from Kenmore. Parts Dept is cheaper.
Posted on Mar 14, 2009
  • 1937 Answers
SOURCE: My kenmore ultra fabric care
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Nov 05, 2010
Lady kenmore washer
Locate contact point under the top section of washer near the lid
Dec 10, 2013 | Washing Machines
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Replace the timer.
Mar 13, 2009 | Kenmore Washing Machines
Kenmore ultra fabric care 80 seris washer
did you try checking your belt to see if its real lose?That might be it!.I have a question for you about this washer,do you know where the lint catcher is?.
Oct 17, 2008 | Kenmore 24902 Top Load Washer
My Kenmore Ultra Fabric care II, 80 series
Hello Friend, The problem is the motor coupler has broke. Replacement is easy, it's installed between the motor and transmission. Almost anyone could replace that part themselves.
Tim, at: JustGetitFixed
Jan 23, 2008 | Dryers
Washing Machines Logo
24 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
