Replaced 5x1000uf10v in power supply still clicking.
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. .
Posted on Dec 19, 2016
I have a Samsung 50 inch TV model 50B450B1DXZA. when I turn it on I get a flashing red light. I have replaced the power supply and X-main boards. they both have correct voltages on them with nothing e
Failure on one of the boards the power supply is servicing may be causing an over current relay to trip repeatedly.
Check PS voltages while the clicking is present to see if one of the outputs is unstable.
Dec 16, 2014 | Samsung Televison & Video
PANASONIC TH-42PD60U will not power on/no power light/have already replace power supply
If your power supply is new try to check the power cord..If you have a volt meter or multimeter range in AC..check the voltage input of your power supply it should have 110v to 240 volts depends on your electrical supply in your outlet..
If no voltage replace the power cord..Hope it helps..
Mar 06, 2012 | Panasonic TH-42PD60U Television
Power supply will not start. replaced 3 bad 1500uf@35volt caps, still will not power up?? (715t2243-1 power supply)
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 25, 2011 | Philips 42MF531D 42 in. LCD Television
I'm working on a sanyo 50" hdtv, It wont power on,
The power supply board have 6 capacitors dead,must have very high current going through the tv to have that many cap to died on the power supply board.U have good electronic skills trouble shoot the power supply board again,have something else is dead in there?Or try website like to buy a refurbish power supply board for the replacement.
Nov 24, 2010 | Sanyo DP50747 50 in. Plasma TV
Samsung ps42q97hd power supply i replaced the blown tric mosfit its still clicking
is better to exchange all power unit , or you must exchange all semicondutor units as (ic, diodes, cap and several resistors), and normaly the board must be burned with heat and loose insulation)
Jul 15, 2010 | Samsung AA-PL0UC6B Power Supply
Power button flashing red will not turn on no clicking noise just nothing
Power supply board is dead,require a new refurbish power supply board for the replacement.Tries websites like, to buy the whole rufurbish power supply for the replacement.Or if u know basic electronic's and basic soldering.Searches the power supply board for these dying,will be dead leaking gases capacitors.Replaced these capacitors will power up stable power to the tv again.These capacitors alway bulges up on it tops or puff up on it tops,that the indication the capacitors are leaking gases and it dying,must be replaced.
Jul 03, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
My samsung ln-t4671f takes 3 to 10 minutes to turn on. it just clicks,clicks clicks
The power supply board is dying,that the board where the power a/c cord into it.Replaced the power supply board will stable and work as normal again.Tries, to buy a refurbish power supply board for the replacement.
Jul 03, 2010 | Samsung LN-T4671F 46 in. LCD Television
My Samsung LN-t4671F LCD TV clicks for about two
You are having another problem with the power board...there are some capacitors which are easily replaced to cave you the cost of the board. If you are technical,I can guide you further,other wise a reputable shop can fix this very reasonably
Jun 07, 2010 | Samsung LN-T4665F 46 in. LCD Television
My phillips flatscreen tv is making this clicking sound and it wont turn on?
Power supply board it dead.Replaced the power supply board to get power back.Tries, to buy a refurbish power supply board for replacement.
Feb 12, 2010 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
